F430 12v feed other than cigarette lighter? | FerrariChat
Discussion in '360/430' started by xMusicManDan, Mar 8, 2023.
  1. xMusicManDan
    xMusicManDan Rookie
    Dec 5, 2022
    14
    Dan Thomas
    Hi All,
    New F430 owner here (literally 48 hours old) and new member here.
    I've read many threads on here which has helped with buying advice/issues etc. prior to my purchase, so really appreciate the community here, it's given me a lot more confidence in ownership.
    Hope someone can offer some assistance.
    I'd like to power a few accessories in my car (Dashcam / Phone Charger etc.) but I like things discreet or at best, very neat and tidy, so I don't want to run a cable from the cigarette lighter in the center console, and have something sticking out.
    Is there a feed somewhere else that is quite easy to get to, and connect to (that will turn on/off with the iginition), that I can use to safely power some accessories?
    Thanks in advance!
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Amazon or e bay do a multi socket extension you can plug into the central consul , works well
  3. CoreyNJ
    CoreyNJ Formula 3
    2,450
    New Jersey Shore
    Have you found them to fit well? I had to wrap electrical tape around the barrel because the Ferrari accessory jack is non-standard diameter by a mm or two.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Works fine in the power socket n the consol
  5. CoreyNJ
    CoreyNJ Formula 3
    2,450
    New Jersey Shore
    Can you see if the Ferrari lighter fits into that socket? I have the Kline exhaust control which fits in the accessory/lighter sockets and doesn't fit in any of the 3rd party outlets I have found so far. When I'm on long trips I want to have other things plugged in and like the OP of this thread, I am looking for a powering solution since I don't have an ashtray anymore with the cup holder so I only have a single power jack. I did investigate using the plug where the lighter socket was, but with the CF console, there isn't even a gap to pass a power cable and I am not drilling a factory CF console for this.
  6. GogglesPisano
    GogglesPisano F1 Rookie
    3,205
    East Bay, California
    Joe
    Few things you can do…
    First, buy the hardwire options for each. It will be less bulky and more reliable.
    You can tap into your radio harness for any easy switched line.
    Or, get a fuse tap and tap into the cigarette lighter fuse.
    Or you can get something like a painless distribution block and wire up a few dedicated circuits.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    It is the lighter socket i am using, the main power socket in the consol will take one of these with 2 x usb and the system voltage displayed. The bananas will not light up through
  8. tmvatlanta
    tmvatlanta Formula Junior
    Mar 26, 2017
    389
    Covington GA
    Tam V.
    van22 likes this.
