News
430 F430 1st gear/2nd gear radio = 14.13/9.28= 1.52
Discussion in '360/430' started by 24000rpm, Jun 14, 2019.
  1. 24000rpm
    24000rpm F1 Rookie
    #1 24000rpm, Jun 14, 2019
    so that means: if you are driving on 2nd gear at 5000 RPM and want to down shift , the rpm after downshift won't be over the rev limiter
    however, i found myself unable to downshift to 1st gear from 2nd gear if i am at around 5000rpm .
    at first I thought it is a f1 pressure issue, i.e. at the moment of downshifting, i happened to have reached the lowest of the f1 pressure thus unable to shift. Alas, that's not the case, as i tested with my leonardo hooked.
    i am guessing either it is a feature of the TCU ( 251619) or my gearbox/f1 system had a problem?
    can someone confirm this?
  2. CarAholic
    CarAholic Formula Junior
    May 10, 2016
    361
    I’d assume that’s a safety system in place that’s relatively high in rpm to downshift in any gear let alone first. Is there a reason you need to down shift to first? First is really only for a rolling gear
  3. 24000rpm
    24000rpm F1 Rookie
    um, as I calculated, from 5000pm 2nd gear to 1st, it will result in 7500rpm or so, so no, it is not high enough, not even close
    my 360s do that just fine.
    I do that for fun. Its just a car.
