Hello everybody, I have a 2009 F430 Spyder which has a faulty ABS pump and module, and I have been searching high and low for one to no avail. Does anyone have leads on one? The part number I require is 221252. It is indeed frustrating to see a car I love being garaged for months, all because of neglect from it's previous owner... Thank you! Image Unavailable, Please Login
Yes..what exactly is the issue you are experiencing and why do you feel you need to replace the pump? The e-diff light on the dash is not related to the abs pump.
Hi everybody, I was advised by my mechanic that both module and pump are broken. I do read within this forum that it is possible to get the module repaired. Currently when I brake hard the brakes will lock up. The ediff issue was solved by my mechanic as it was a cluster issue.
got a used ABS unit from overseas sourced by my garage. Spent a total of $4k usd with labour and got all lines flushed. Rare as hens tooth for later model 430s these pumps and modules
This is interesting to me. I have never encountered an ABS module failure on a 360 or 430. What were the faults etc?
I have the same issue on a 2008 F430 with the hydraulic circuit clogged. The right front circuit is clogged. Looking for a replacement Bosch abs pump if anyone has one.
I have one in the shop right now that appears to be bringing down the canbus system. Cluster is lit up with all warnings and have bus faults in other modules that go away when ABS unit is unplugged. UpFix is able to rebuild the modules in days, sending mine out tomorrow
