F430 - Ambient Air Temp Sensor Location? | FerrariChat
Discussion in 'Technical Q&A' started by malibumk, Dec 18, 2011.
  1. malibumk
    malibumk Karting
    May 14, 2002
    167
    Malibu, CA
    Mike Klein
    Can anyone help me locate the "Ambient Air Temperature" Sensor on an '06 430 please? The one that is part of the fuel control system.
    Thanks,
    MK
  2. PT 328
    PT 328 F1 Rookie
    4,004
  3. Sled Driver
    Sled Driver Formula Junior
    May 13, 2010
    494
    Stokesdale, NC
    Emery
    Driver's (L/H) door mirror. It's that little black button sticking out at the bottom of the mirror
  4. malibumk
    malibumk Karting
    May 14, 2002
    167
    Malibu, CA
    Mike Klein
    Thanks guys.........much appreciated.
    Please confirm: is this sensor input used as part of the OBD II system ......drives failue codes?
    MK
  5. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    I have a feeling that the sensor on the wing mirror has more to do with Air Con than fuel / combustion.
    I suspect there's probably another one in the inlet system somewhere.
    Anyone?
  6. malibumk
    malibumk Karting
    May 14, 2002
    167
    Malibu, CA
    Mike Klein
    Lessons Learned Feedback; YES the ambitent Air Temp Sensor under the Driver Side Mirror is for BOTH the A/C System and the OBD II.
    What I found was an intermittent fuse for the a/c control (10A behind drivers seat) and when the a/c is out, it also triggers the Check Engine light.
    Fix fuse.....fix both.
    MK
  7. wang
    wang Formula 3
    Feb 23, 2004
    1,998
    Brunei
    H. Wang
    Thanks for the useful info. :)
  8. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Yup! Thanks for posting back that info.
