F430- and (not "vs") the Porsche 911 Turbo | FerrariChat
Discussion in '360/430' started by RBK, Jun 9, 2007.
  1. RBK
    RBK F1 Rookie
    Jul 27, 2006
    3,105
    Calif and Nev
    Bob
    This may be a repeat although I have never seen it before. From Winding Road Magazine the following was noted between the two vehicles. I found it informative and another example of how different two very "comparable" cars can be. Anyone owning both cars knows these are two very different automobiles, but anyone choosing either will not be disappointed. Best
    STORY
    Advance numbers do tell some of the story between these two absolutely sensational driver’s cars. Whereas the 4.3-liter V-8 in the Ferrari F430 creates 490 horsepower peaking at 8500 rpm, the 3.6-liter twin-turbo flat-6 in the Porsche 911 Turbo is now good for 480 horsepower at 6000 rpm. Our 911 Turbo with six-speed manual weighs in at a Porsche-estimated 3495 pounds at the curb, while the F430 with F1 paddle shifters scales at 3350 pounds (we’ve weighed one ourselves). Hence the weight-to-power figure for Porsche is 7.3 pounds per horse to Ferrari’s 6.8 pounds per horse. Yet the admittedly conservative manufacturers’ estimated acceleration time to 62 miles per hour is 3.9 seconds on the manual Turbo and 4.0 seconds for the F430. (We’ve personally taken the manual Turbo to a 3.7-second run and the F430 to a 3.8-second run.) They can both go near 190 mph with pedalto-metal, but this isn’t the big deal.
    On such cars, the big deals are driving dynamics and power delivery during long technical stretches. Highway S65 that happily traverses both high passes in this story is a remarkable piece of work. If you seek a long, satisfying drive in a foreign place, S65, and the arterial two-laners that run up to meet it from the surrounding valleys, is the ticket. Both the Porsche and Ferrari simply glowed, they were having so much fun.
    Regarding handling, a fundamental difference here is the Turbo’s viscous all-wheel-drive design that varies constantly between zero and 100 percent of torque-split between the front and rear axles. And torque, you say? Therein lies the rub that ultimately equalizes these two in raw power and speed. Whereas the Ferrari peaks rapidly at 5250 rpm with 343 pound-feet of torque, the Porsche with its 17.4-psi variable turbine geometry turbochargers (14.5-psi without Sport-Chrono) booms away on 460 pound-feet of it available anywhere from 1950 to 5000 rpm. Plus, the Porsche, with optional Sport Chrono in sport mode, gets an over-boost to 505 pound-feet between 2100 and 4000 rpm. In the Ferrari, we keep the revs high while at play. In the Porsche, we could let revs drop low for an utterly separate sensation while duking it out with the Italian. The Ferrari F1 transmission with paddles is the best of its kind in this business, especially as it mates so well to the rev characteristics of the V-8 engine. Porsche’s five-speed Tiptronic S sequential gearbox is not our favorite unit, but the six-speed manual here is slick and fits the Turbo power and torque like a glove.
    This personality difference—pure Mediterranean passion versus serious German business—carries over into all aspects of each car. Idle speed for the Ferrari V-8 is set at a bubbling 1000 rpm, while the Turbo flat-6 rumbles steadily at 750 rpm. Exhaust notes under hard power and launching between curves are yelling out loud on the F430, and down and nasty for the Turbo. The Ferrari interior is exactly what we all picture in our heads when it comes to “piloting” a car while nestled down in the “cockpit,” whereas the Porsche is ultimately better to live with over longer drives.
    There is a nimbleness in the feel of a mostly aluminum body and chassis, and the Ferrari has this tight and light sense to it. The feeling is aided and abetted by the fairly light feel at the wheel versus the thick and hearty steering weight of the Porsche. Lock-to-lock steering takes 3.1 turns in the F430 and just 2.6 turns in the Turbo, but the all-wheel drive necessarily removes a tad of the steering satisfaction from the experience with the Porsche. With its rear-wheel drive and brilliant E-Diff torque wrangler working discreetly behind the scenes, the steering action on the F430—admittedly our favorite current Ferrari by a mighty long shot—is exactly as we would want it. Under the pressures of high-performance conditions, the Ferrari is sheer fun, though the Porsche is more efficient about getting you to point B. Both GTs have road-holding down to an art, but the revs go so high, so fast in the Ferrari that it can cause more unplanned excitement than the rock-steady Turbo.
    Though our Porsche Turbo did not come with the $8840 optional Porsche Ceramic Composite Brakes (PCCB), the standard drilled and vented 13.78-inch cast-iron discs at all four corners worked fine throughout the two days, and the pedal feel was the most progressive of the two cars. Ferrari did gift us with their optional $16,808 ceramic disc set and, dang, but they do stop a car dead in its tracks. The feel is like sandpaper discs rubbing calipers made of cinder block, sure, but once you get over that indelicate sensation, you love the things for the precision and efficient late braking they’re designed to provide.
    When it comes to Porsche Active Suspension Management (PASM) plus Porsche Stability Management (PSM) plus Porsche’s Sport Chrono package, versus Ferrari’s Control for Stability and Traction (CST) via the manettino switch mounted lower-right on the steering wheel face, the F430 system is tidier, but both arrangements are stellar once you get your favorite setup. Our default on the Porsche Turbo for these two idyllic driving days was PASM in sport with Sport Chrono in sport (for quicker throttle response and the torque boost), wing up, and PSM poked off. In the Ferrari, setting the manettino in sport (faster throttle, faster shifts, stiff suspension, and higher thresholds for CST and E-Diff corrections) is great, and in race mode you just need to be sure that the road ahead is pretty smooth, because it’s hard. Putting the manettino in race/CST-off mode should generally be left for track days. Set up as described, both cars took everything we tried throwing at them and spit it back at us.
    Okay, so the F430 starts at $177,929, while the Porsche Turbo begins at $123,695, but once you get up here into these privileged seats you’re not mainly concerned with the cost. Usually you know which one you must have, or, if Lady Luck has really drawn your number in life, you buy one of each and run your own comparison tests at your nearby private track whenever you like.
  2. raw tubor
    raw tubor Karting
    153
    It's a good comparison. I also think the final thought -- that if you can afford it, get both -- contains more than just a tad of humor.
    With the Ferrari, you get the 'hollywood tuxedo' at a tuxedo price, admired and noticed by all, spotless and gleaming, on stage for all to see. And you pay a very heafty price to maintain its looks and functionality. But no one wears a tuxedo to work every day, and thus the 430, like a tuxedo, will 'hang in the closet' most of the time untill a stellar day and special occassion bring it out. Every one of those special outings will be glorious.
    With a Porsche 997TT, you don't get noticed as much, you don't worry as much about it looking spit polish all the time, you'll drive it work everyday w/o much thought, and you'll pay a reasonable price to maintain its functionality. And, best of all, you'll actually fill your days with driving the thing, rather than having it hanging in the closet, depreciating all the time. Every one of those days driving it will be a fun drive.
    Glory + functionality = Ferrari + Porsche in the barn.
  3. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,828
    Florida
    Lee
    This comparison is the best I have read. Someone did a great job in really thinking out the driving experience and putting it to written word.
    Thank you for sharing this with us.
    Lee
  4. carbon_00
    carbon_00 Formula Junior
    May 5, 2006
    746
    Toronto/London, UK
    Scott
    I drive my F430 to work nearly every day...forget leaving it in the garage.
    NMNMNMN likes this.
  5. SrfCity
    SrfCity F1 World Champ
    I'd like to read a hard corps comparo between the the 430 and a GT3. Although the 430 is more civilized for street use. ;)
  6. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    Thanks for posting...great read.
  7. RBK
    RBK F1 Rookie
    Jul 27, 2006
    3,105
    Calif and Nev
    Bob
    Noteworthy.
    I dropped my 430 off at service Friday (rattling exhuast which service manager says Ferrari replaces entirely rather than any one piece -I like that) and the service manager and I were chatting about cars in general and his opinion(s). He said something I have thought was telling about Ferrari owners. He said, 75% of the people who come into his shop are very nice people, but also could care less about anything but the sound of the motor and looks of the car (and using his words) how much they impress the "babes". He said most Ferrari owners he meets, don't have a clue as to the exact amount of horsepower or foot pounds of torque and could care less. I guess I (and most here) are in the minority. Best
  8. SpeedGeek
    SpeedGeek Karting
    Oct 10, 2006
    134
    Jo'burg, S. Africa
    Warren
    Great report and comparison - thanks for posting.
    I drive a 996 GT3 RS as my daily transport. My brother has a F430 as a weekend car. Before the F430, he had a 996 Turbo as a daily driver. I have also driven the 997 GT3 and GT3 RS.
    I read many reports comparing the F430 with the Porsche Turbo, yet far fewer comparing the F430 with the GT3 variants. This is odd because it's the GT3 cars that are so similar to the F430, not the Turbos. I assume this oversight is due to the Turbo's bigger power being closer to the Ferrari's, but in terms of driving character, the TT really feels more of a GT than an outright sports car. The F430 and the GT3 are both true sports cars.
    Regarding real world performance, the F430 and GT3 are extremely closely matched. Both provide the same screaming, linear, naturally aspirated power delivery, RWD handling characteristics and rigid sports car suspension. The Ferrari's power/weight advantage over the GT3 is so minimal out on the road that I can hardly tell the difference. My brother and I have had the rare occasion or two to go head to head, and it's only well into triple digits that the Ferrari's extra power makes any meaningful difference, both cars hauling like missiles to beyond 8k rpm. And the 997 GT3's added power and lower gearing give it a touch more in-gear shove over my 996 RS.
    The Turbo's Herculean torque and much lower redline give it a totally different power delivery to the GT3 or F430. It's also quieter, softer, heavier and 4WD. If it looks similar to the F430 on paper, it feels nothing like it in reality. I have not driven the 997 Turbo, but from the passenger seat it's still more GT than sports car.
    IMHO, the Ferrari is the perfect weekend sports car. Certainly it can be used daily, but it just feels a bit too precious for that. I use my 996 RS as my daily driver, but saner people probably would not. The rear springs on the 996 will probably require that I have my kidneys rebuilt at some point, and my teeth retightened, but what can I say - I'm addicted. The 997 versions with PASM are much, much more comfortable.
    The Porsche Turbo makes a perfect daily driver, but other than at WOT, it's just so darn boring.
    Some pics of our cars:
    F430
    996 RS
    Road Trip
  9. SrfCity
    #9 SrfCity, Jun 11, 2007
    Great description of cars. Plus some spectacular photography! I like these for starters :)
  10. fun-meter
    fun-meter Formula Junior
    Nov 12, 2006
    255
    Kent, UK
    Lewis
    Some nice comparisons between the two.
    The F430 can almost be used as an every day car, but as mentioned, its a bit more 'precious' and 'in your face'. The 996 GT3 Mk.2 that we use to have could be used every day (although a bit of hard ride) as it was in Grey so it didnt stand out as much. The F430 compared to a GT3 or a Turbo can be done in terms of performance, and they do all look good, but the Ferrari is certainly more class and makes a very nice exhaust note.
    Although the Porsche was a bit more hard wearing compared to first service of the two cars:
    - 996 GT3 only needed air and oil filter change (requested oil change as well) at 10,000 miles.
    - The F430 (just came back from service) had all the usual geometry setup, plus some filters, oil, the two recall parts, a few bearings, a few other little bits (indicator bulb etc..) and a slight oil leak (a 'sweat') and a few mm's of tire wear after 4,800 miles.
    Doesnt mean we dont like the car though, no major complaints. Cant beat a Red Ferrari, looks and goes so well.
