F430 Battery recommendation? | FerrariChat
Discussion in '360/430' started by mjz, Aug 25, 2018.
  1. mjz
    mjz Karting
    Aug 3, 2007
    163
    Houston, Texas
    Michael
    Would someone point me to threads that discuss what battery is highly recommended for the F430?
    I am looking for more recent threads (last couple of years) for up to date recommendation.
    My Red Top Optima is terrible - and I am finally going to replace it after only 3 years (always on a Ctek tender).
  2. cpep
    cpep Formula Junior
    Nov 11, 2017
    399
    new york
    CHARLIE
    I used an odyssey.
  3. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    552
    SW Suburbs of Chicago, IL
    Lawrence P.
    My Ferrari dealer installed an Interstate in my 360 Spider just before I purchased it. No problems and always use my CTek.
  4. mjz
    mjz Karting
    Aug 3, 2007
    163
    Houston, Texas
    Michael
    Which one?
  5. Edgar Diaz
    Edgar Diaz Karting
    Sep 13, 2014
    198
    Alabama
    Edgar Diaz
    I have Interstate. I’ve had it for four years now and no problems. Always on tender.
  6. cpep
    cpep Formula Junior
    Nov 11, 2017
    399
    new york
    CHARLIE
    34r-pc1500t
  7. BlacktopRacing
    BlacktopRacing Formula Junior
    Sep 18, 2016
    916
    Pittsburgh
    Dale
    Optima batteries are junk, and have been junk for a out a decade now. Not even sure how they stay in business.
  8. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    877
    Georgia
    Mark Gronsbell
    Interstate AGM. Check their catalogue for correct one to fit. Decent cost and good quality.
  9. Dicecal
    Dicecal Formula 3
    1,804
    Phoenix, AZ
    Rob
    The top Interstate is the one...
    Bob in Texas likes this.
  10. SCKOMS
    SCKOMS F1 Rookie
    3,849
    Lake County, IL
    Spiro
    Mine died in the driveway on a Sunday afternoon. Got a Die Hard AGM from Sears as they were the only place open nearby. Works great!
    Sent from my Galaxy
  11. f355spider
    f355spider F1 World Champ
    17,940
  12. TheMayor
    TheMayor Nine Time F1 World Champ
    98,784
    Vegas baby
    Interstate Megatron.
    One of the best you can buy. Awesome battery.
  13. dreichman
    dreichman Formula Junior
    Sep 9, 2011
    425
    Denver, CO
    Had Interstate for five years. Never had a problem. Replaced it because of age. Replaced it with the same battery. It’s now two years old and again, no problems. Also, it’s always on Ctek charger.
  14. Carnut
    Carnut F1 Rookie
    3,797
    Gladwyne PA
    Morrie
    So did I.
  15. mjz
    mjz Karting
    Aug 3, 2007
    163
    Houston, Texas
    Michael
    I decided on Interstate - the product codes are different from a few years ago. Need to decide on either:
    MTX-48/H6
    or
    MTZ-48/H6
    The MTX and the MTZ have different dimensions. Which one will fit?
    MTX-48/H6 H6 760 950 120 70
    11 by 6 7/8 by 7 1/2
    MTZ-48/H6
    10 15/16 by 6 7/8 by 7 7/16
    Any idea on if the positive and negative terminal are correct for the 430?
    thanks
  16. shifter
    shifter Formula Junior
    625
    Danville, Ca
    Joe
    I prefer odyssey batteries, I’ve had a lot of good luck with them.
  17. RedNeck
    RedNeck F1 World Champ
    10,014
    The CSA
    Me
    I use an Odyssey PC925 in my 360, no problems so far but does seems to take longer to charge 100% than the interstate I had in their before. I really hated how cramped the battery compartment was with a full size battery.
    whatheheck likes this.
  18. RichardCH
    RichardCH F1 Rookie
    4,661
    most super small dry batteries thus far are frankly useless, been there done that, won't be doing it again, look up Mark Stewarts Bosch S5 recommendation
  19. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,247
    So Cal
    Bert
    Bosch AGM, @Pep Boys, on sale for under $150. Good reviews, charged it up and that sucker put out almost 900 CCA !
    f355spider and whatheheck like this.
  20. CarAholic
    CarAholic Formula Junior
    May 10, 2016
    514
    Any update on this
  21. bellwilliam
    bellwilliam Formula Junior
    Oct 25, 2014
    398
    #22 bellwilliam, Dec 19, 2018
    Interstate MT7-48/h6 was what Interetate recommended last year. Bought one.
    This fits perfectly.
    MTZ-34R is what Interstate recommends now.
  22. ShadowF430
    ShadowF430 Formula Junior
    Mar 29, 2017
    270
    Portland
    Jason
    I’ll be getting the mtz. Interstate recommends the 34r but I think the H6 is a better fit since it’s just a hair smaller. It’s a tight fit and the extra few cm will help in the 430.
  23. caymangone
    caymangone Karting
    Jan 13, 2017
    79
    Missouri
    #24 caymangone, Mar 10, 2019
    MTZ-34R is the one called out for the 430. Its a little taller and the threaded rods doesn't allow for the hold down bar to go across the top leading edge of the battery case but there are a couple of ridges molded into the casing that the bar catches further down. It cinched right up and isnt going anywhere. Plenty of clearance between the top posts and anything metal. No mods needed.
  24. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,207
    Santa Barbara County
    Sam
    I just went out and I discovered my battery charger stopped working (no light) and my OEM battery from Jan. 2008 is dead. I have taken it out and will replace it tomorrow. It seems after reading these threads, I should either get the Odyssey 34R-PC1500T ($360) or the Interstate MTZ-34R ($255). Is one better then the other? Will one last longer (It was a PITA getting that battery out).
    Thanks for any responses
