F430 Becker Radio CD Stuck | FerrariChat
Discussion in 'Technical Q&A' started by cs1, Aug 7, 2011.
  1. cs1
    cs1 Formula Junior
    Oct 11, 2010
    304
    Mr X
    I have an F430 coupe fitted with Becker 6111 Cascade. CD changer works but CD in single slot won't eject when I press eject - just keeps playing. What else could I try to get it out?
  2. Stevely
    Stevely Formula Junior
    Jul 21, 2011
    634
    LA, CA
    Did you ever get this fixed? My Burned CD won't eject as well. The CD spins but doesn't play. Other CD's work fine but I can't get it out now.
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    I've read the otherwise comprehensive Becker Cascade 6111 Operator's Manual (nice unit-even does your laundry) and I can post the pdf for th manual upon request. No help in the manual.
    Emergency Eject - Many cd radios have a tiny inconspicious hole near the CD to poke a straightened paper clip as a tool for help. Try in several positions of power on/off etc. Even try the eject button with the menu in other functions.
    The 6111 manual warns mentions several times again burnt cd, fearing copyright issues. I suspect they intentionally cater to the copyright holders by capturing them much as old VISA card machines would keep cards which had expired or over-withdrawn. Loose cables can cause binding and require careful intervention with a pocket ruler.
    One trick it a steel pocket I've used is an engineers ruler using double sticky Scotch tape and attempting to grab the cd with adhesion of the tape.
  4. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    [ame]http://www.youtube.com/watch?v=PopfoNquln4&feature=related[/ame]
