430 - F430 big brake kit 2023 | FerrariChat
430 F430 big brake kit 2023
Discussion in '360/430' started by JM280z, Jul 3, 2023.
  1. JM280z
    JM280z Formula Junior
    Aug 22, 2020
    878
    Jake
    Hey All,
    Does anyone have suggestions on a big brake kit for an F430? I’ve heard about using Z06 calipers and rotors but haven’t found specifics. OEM carbon ceramic calipers are hard to come by.
    Any kits I’ve found lose ebrake which is no-bueno for a street car of course.
    Buying girodisc rotors and pads at non-ceramic sizes is about $4k from FabSpeed so for a few grand more I figure I can get way larger rotors (mainly for looks).
    Thanks!
  2. coinball
    coinball Karting
    Dec 1, 2004
    80
    Raleigh, NC
    Eric
    I just purchased the Brembo GT kits front and rear (which does retain the rear ebrake), currently waiting on Brembo to piece them together (made to order kits) and ship them out.
    ETA - I had the same dilemma, I really wanted CCM calipers + girodisc for the ultimate flex, but that combo was more expensive than just getting the Brembo set. The good news is that avoiding the CCM calipers is hopefully one less problem down the road with the pistons sticking in them.
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Fit the hill engineering stainless pistons and no more issues.
    LorenzoR likes this.
  4. LorenzoR
    LorenzoR F1 Rookie Rossa Subscribed
    Sep 26, 2015
    3,172
    Sarasota Fl/Pittsburgh
    Thats what I did
    I bought oem calipers and rebuilt them with hills pistons. Then bought girodiscs. Glad I did now
  5. JM280z
    Aug 22, 2020
    878
    Jake
    What source did you use for purchase?
  6. coinball
    coinball Karting
    Dec 1, 2004
    80
    Raleigh, NC
    Eric
    I purchased thru vividracing.
  7. coinball
    coinball Karting
    Dec 1, 2004
    80
    Raleigh, NC
    Eric
    Here are the part numbers for what I ordered in case anyone is looking for them:
    2M3.9002A5
    1M3.9008A5
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    If you goto a ferrari dealer with seized caliper pistons, they will fit new calipers- might be worth asking if any used ones available and then fit the hill engineering pistons
  9. JM280z
    Aug 22, 2020
    878
    Jake
    Smart suggestion!
  10. JM280z
    Aug 22, 2020
    878
    Jake
    Here is the distributor list for F430 Brembo brakes. I think 380mm is base model rotor size front, and 355mm rear. Correct me if I’m wrong. Therefore, I’d rather just do new rotors and pads if the size is remaining because I’ll never hit max capabilities of stock brakes on the street, especially with Motul 660. I’d only upgrade to CCM sizes for looks, assuming price is <$10k.
  11. WillskiGT
    WillskiGT Formula Junior
    Aug 12, 2017
    444
    Steel 4 piston calipers are 330mm front and rear.
    CCM 6 piston are 380mm front, 355mm rear.
    Stock steels are fine if you upgrade pads and fluid.
  12. JM280z
    Aug 22, 2020
    878
    Jake
    If these are larger steel options, I wonder if the original ebrake caliper transfers over, if they got a bracket extension for it or not.
    To upgrade the size of rotors (for looks) and street use, what kit do any of you think is be Image Unavailable, Please Login st?
    The first pics were blurry so here is better ones. Image Unavailable, Please Login
  13. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,018
    NE FL
    Ken
  14. JM280z
    Aug 22, 2020
    878
    Jake
    I don’t think the KSport ones have ebrakes.
