F430 Broke Down- CV Spewing Grease - Replace or Repair | FerrariChat
Discussion in '360/430' started by JM280z, Jun 15, 2025.
  1. JM280z
    JM280z Formula Junior
    Aug 22, 2020
    878
    Jake
  2. JM280z
    Aug 22, 2020
    878
    Jake
  3. JM280z
    Aug 22, 2020
    878
    Jake
  4. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,775
    Lake Villa IL
    Maybe the bolts are loose? Seems odd to be leaking otherwise
  5. JM280z
    Aug 22, 2020
    878
    Jake
    Yes! The bolts were actually quite loose…. 1/3 were finger loose 1/3 required just a pound of pressure with a 6” handle. The rest were snug.
    Cleaned. It’s leaking between the plates, then migrates along the bolts, where it leaks at top and bottom of bolt. I don’t understand the assembly of this; could the loose bolts not have been sealing the assembly plate enough?
  6. JM280z
    Aug 22, 2020
    878
    Jake
    Are you sure loose bolts could cause this? If so, I’m guessing that’s the cause.
    Second thought, do I need to add grease?
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,951
    Central NJ
    Dominick
    My friend ROn made this a few years ago - this may help you see how it goes together etc
  8. JM280z
    Aug 22, 2020
    878
    Jake
    Can you share the raw URL and/or name of video? It’s saying broken link for me. Thank you for sharing!
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,951
    Central NJ
    Dominick
    see if this works
  10. JM280z
    Aug 22, 2020
    878
    Jake
    Fantastic video and he’s got a great looking F430, looks like quality work. I’ll just rebuild them both for preventative maintenance.
    flash32 likes this.
  11. JM280z
    Aug 22, 2020
    878
    Jake
    Here is another video if anyone else needs reference:
  12. DiSomma6
    DiSomma6 Karting
    Nov 27, 2023
    227
    Erik
    Yes, that looks like just loose bolts to me. Those are known to come loose over time.
    However, your boot is just starting to balloon, so I'd plan on a boot replacement soon, depending how much you drive your car. The axles and CV joints will outlive you if they never get water or dirt in the grease. The replacement kit from Ferrari comes with both boots, clamps, end caps and 2 tubes of grease.
  13. JM280z
    Aug 22, 2020
    878
    Jake
    Why would a boot swell? Excess heat? Maybe a symptom of a greater problem.
  14. DiSomma6
    DiSomma6 Karting
    Nov 27, 2023
    227
    Erik
    It's mostly age. The rubber eventually thins with constant rotation and the boot starts to lose it's accordian shape. After rotating out of shape, they will eventually tear and you'll lose your grease. As long as it's caught in time, it's a simple boot replacement. They will typically balloon just before they break.
    JM280z likes this.
  15. JM280z
    Aug 22, 2020
    878
    Jake
    Fantastic explanation! Thanks
  16. omega_jeff
    omega_jeff Rookie
    Oct 20, 2024
    4
    The larger OEM hose clamp on mine seemed to loosen up and was spewing grease as well. There's no way to tighten it, unfortunately. I ended up replacing it with an Oetiker clamp. Problem solved!
  17. GogglesPisano
    GogglesPisano F1 Rookie
    3,217
    East Bay, California
    Joe
    There are many other reasons as well. First I've heard of the boot ballooning from "thinning" but I'm not a mechanic either. It could be overpacked or the small end could have been cinched too far down the axle shaft. Either way, if it's permanently deformed, it should be replaced. If it springs back to the normal shape once you've removed the straps, I'd run it.
  18. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,782
    The boot likes fine to me. The crease just needs popping back into shape.
  19. Rifledriver
    37,110
    The bolts if tightened correctly never come loose and the boots distort from heat. Someone has had it apart and caused this. Also CV joints get stuffed with too much grease (more is not better) all the time and spewing out is caused by that as well. Take it apart, clean it, replace the boot, repack with correct amount of grease and properly tighten the bolts. Fixed.
    CoreyNJ and GogglesPisano like this.
  20. JM280z
    Aug 22, 2020
    878
    Jake
    What’s considered too m
    what’s too much grease? Did normal guy super car (video above) use too much? It seemed like a lot.
    I could also see how excess grease causes boot to sweep and eventually crack due to the force of that grease in there while it’s spinning.
  21. Rifledriver
    37,110
    Umm no.
    There is a spec for grease quantity. Typically out of ignorance people use too much.
  22. JM280z
    Aug 22, 2020
    878
    Jake
    Here is the kit. 70000868. Same part number and half the cost if labeled “Maserati.”
    I’ve rebuilt plenty of u-joint drive and half shafts; looking forward to doing this one.
  23. Mercedes_Benz
    Mercedes_Benz Formula Junior
    517
    South Florida
    I don't think I would have called a leaking CV boot a broken down Ferrari.......
  24. JM280z
    Aug 22, 2020
    878
    Jake
    I towed it home due to a lot of smoke from the grease going onto the test pipes. Which I’m guessing could ignite too. I’d say that was justifiable / smart to tow.
    Mikemt787 likes this.
