F430 bypass valve rattle | FerrariChat
Discussion in '360/430' started by LorenzoR, Aug 20, 2017.
  1. LorenzoR
    LorenzoR F1 Rookie
    #1 LorenzoR, Aug 20, 2017
  2. klointheridge
    klointheridge Karting
    Jun 5, 2017
    219
    Westchester Cty, NY
    Kevin Long
    Stupid question...but what did the rattle sound like? I have something going on at start up but it disappears after about 30 seconds
  3. LorenzoR
    LorenzoR F1 Rookie
    I thought at first it sounded like a screen rattling or vibrating. After 30 seconds it went away. So a couple days ago i took off the diffuser off, i started her up and quickly went to the rear of the car with a screwdriver. I wedged it into that arm of the bypass valve and the rattle stopped.
  4. vv23
    vv23 Formula Junior
    Jan 8, 2009
    259
    Edmonton, Alberta
    V V
    I have the same problem.
    Can you tell me where you got that spring. Or dimensions of it etc.
    thanks
  5. LorenzoR
    LorenzoR F1 Rookie
    I got the springs at a BUSY BEAVER hardware store. I can measure them up tomorrow
  6. klointheridge
    Jun 5, 2017
    219
    Westchester Cty, NY
    Kevin Long
    Very interesting! Was it really loud? I can sometimes kick it away w a flick of the gas pedal.
  7. Speedracer800
    Speedracer800 Formula Junior
    511
    Chicago, IL
    Another way to check if it's your valves making the suspect noise is to disconnect the vacuum hoses from the valves which will cause the valves to remain open. The rattling from faulty valves occurs typically when the valves are closed. Disconnecting the vacuum lines will be help isolate the noise you're hearing.. If it goes away after disconnecting then it's safe to assume your annoying noise is indeed the valves.
    Great fix with the springs.. Just a little lateral tension on the valve is all it takes to solve this. Seems like its caused by normal wear on the shaft / shaft bushing in the valve assembly which creates the rattling.
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,948
    Isle of man- uk
    Nice to see my idea put into practice
  9. LorenzoR
    LorenzoR F1 Rookie
    Hi Mike, i thought it was you i was just to tired last night to search it to make sure. Thanks for the idea. That rattle drove me nuts
  10. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I think my F430 have the same problem.
    Kindly share the dimensions of the spring please, or perhaps if anyone knows where we can order it online.
    Thanks!
    Dan
  11. LorenzoR
    LorenzoR F1 Rookie
    #11 LorenzoR, Aug 21, 2017
    Okay I just took it back off so I can get a good measurement and a picture for you guys. I hope it turns out okay cuz I'm doing this from my phone
  12. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Excellent! Thanks for sharing photo and info.
    Now time to find a seller.
    Will share what I find here.
    Dan
  13. f355spider
    f355spider F1 World Champ
    18,043
    On the F355 the fix for the rattle was to remove the diaphragm (couple nuts holding it to the bracket. Then loosen the nut on the shaft and unscrew the diaphragm a couple turns. Tighten the nut and reinstall. This adds a little preload on the valve to hold it shut. It is presumed there is a loss of tension causing the valve to rattle.
    One has to be careful with the adjustment, if you add too much pretension it can prevent the valve from opening.
    Looking at the photos, there may be enough room to remove the circlip from the shaft, loosen the lock nut and do all this from below?
    Again, only add one or two turns, whatever is required to eliminate the rattle, but avoid it stay constantly closed from too much pretension.
  14. Speedracer800
    511
    Chicago, IL
    Yes.. I tried that fix also but it didn't resolve it for me. It seems like you need a little bit of lateral pressure on it to quiet them down.
  15. f355spider
    18,043
  16. 24000rpm
    24000rpm F1 Rookie
    that could be your exhaust box giving up
  17. 24000rpm
    24000rpm F1 Rookie
    ha, that looks like an old school mechanical gas pedal return spring
  18. LorenzoR
    LorenzoR F1 Rookie
    Yea funny you mention that. Your rite. Looks like something youd see on a 4 barrel carb haha
  19. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,948
    Isle of man- uk
    Where i used to work, we had springs on a few things as a quick fix, but they tended to be a permanant fixture in time.
  20. vv23
    vv23 Formula Junior
    Jan 8, 2009
    259
    Edmonton, Alberta
    V V
    Do you have any more info on the springs? My exhaust valves rattle also, want to see if this can fix it.
