F430 CF rear challenge grill. | FerrariChat
Discussion in '360/430' started by mix'nitup, May 28, 2008.
  1. mix'nitup
    mix'nitup Rookie
    May 7, 2008
    25
    San Jose, Ca
    khanh
    #1 mix'nitup, May 28, 2008
    I have been looking for an 05 F430, then I saw an 06 with this option, a carbon fiber rear challenge grill. I know it's common on the 360 but never seen it on an F430. Is it an after market or a factory option?
    khanh
  2. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Santa Barbara County
    Sam
    It was an option on my 07 F430. I think around $2800. The ones on the 360 are not cabon fiber.
  3. mix'nitup
    mix'nitup Rookie
    May 7, 2008
    25
    San Jose, Ca
    khanh
    Your are right Sam and thanks for the info.
    Khanh
  4. Tarek K.
    Tarek K. F1 World Champ
    10,798
    Cairo - Egypt
    Tarek K.
    Like Sam said, it's a F430 factory option..........the option code is "GRDC" and is called "Challenge Style Rear Segment in Carbon Fiber".
  5. jais
    jais Karting
    May 27, 2005
    175
    ATL
    I have this on my '07 430 also. I understand it was only available for a short period of time.
  6. mw575
    mw575 F1 Rookie
    May 30, 2001
    2,924
    Lake Oswego,Or
    Martin J Weiner,M.D.
    Still available= $2900 (euro up vs $)
  7. TimsBlack16M
    TimsBlack16M Formula 3
    Jan 27, 2005
    1,365
    Agoura Hills, CA
    Tim
    Still available...it will be on my 9/08 delivery.
    Tim
  8. 483hp
    483hp Formula 3
    Aug 17, 2005
    1,428
    www.fca.alberta.com
    The challenge grill is a factory option. It can also be retrofitted as well, but it requires a new bumper. If you are looking for a pre-owned vehicle with this option, look for a mid year 2006 build or later. This showed up as a new option in MY2006 on builds starting in May.
  9. mix'nitup
    mix'nitup Rookie
    May 7, 2008
    25
    San Jose, Ca
    khanh
    So it's safe to say , it's a good thing to have? The reason I said that because it looks like the one on "The" Scuderia and i don't want people to think I have it on my car because I want my car to look like a Scuderia by getting an imitation for it!
    Thanks to all that chime in.
    Khanh
  10. TheMayor
    106,023
    Vegas baby
    I ordered it on my 08. I like the regular F430 rear but (to me anyway) this one makes the car look just a bit meaner and a bit lower.
    Plus, I'm told it cools better and I'll be running it in some pretty hot environments. I'm not sure how many F430's have been made with it but I think it's fairly rare in the total production run. I didn't even realize it was on the Scuderia until after I ordered it. I knew it was the Challenge race cars.
    My understanding is that a "retro fit" runs about 14 grand. So, unlike the realitively easy 360 swap, a 430 retro fit may not be worth it given the cost involved.
    Personally, I like the 430 either way but I really like the 360's to have Challenge grills.
  11. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    The Scud has a grill that looks like the one on our F430s... our cars were out first :)
    I don't think anyone would consider you ripping off a Scud if you ordered your F430 with the CF grill. I, too, think the F430 looks better with the CF grill than without.
    When I had my 360, I had a Challenge Grill and no one suggested I did this to look like the CS.
    Order it with your car... it's an awfully expensive retrofit after the car leaves the factory.
    Frank
  12. Tarek K.
    10,798
    Cairo - Egypt
    Tarek K.
    It's also on the F430 Challenge car...........it's an authentic factory option for the F430 which exists prior to launching the Scuderia. It's a great looking option and also aids the engine cooling.......the mesh on the CF Challenge grille is larger than the mesh in the standard F430 bumper.
    I also have the CF rear Challenge grille on my F430 and I love it.
  13. jais
    jais Karting
    May 27, 2005
    175
    ATL
    When I put my hand up to the grill after the engine warms up it is very obvious that a lot of heat is escaping the engine compartment via this grill. As the rear grill is near the exhaust system and muffler, this seems to make sense.
  14. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    I think the challenge grills look great on the 360's.
    However, IMO, on the F430's, the challenge grill has too much flat surface area and looks a bit out of place, like an aftermarket piece of add on, unless of course you have a black car that blends it in a bit better.
  15. Blue4reF1
    Blue4reF1 Formula 3
    Jun 12, 2007
    1,475
    Plantation, FL
    Blake Simon
    4,000 posts.. lol.. :D
  16. mix'nitup
    mix'nitup Rookie
    May 7, 2008
    25
    San Jose, Ca
    khanh
    You are right, it came out before the Scud. I'll use that one. hehe.
    khanh
  17. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    F'k YEH!!!!
    All time well-spent!!! LOL!!! :D
  18. apbc2
    apbc2 Karting
    Dec 1, 2006
    53
    NY
    #18 apbc2, May 28, 2008
    JoeDoyle likes this.
  19. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Sam
    I think you should change your name to ILUV2Post
  20. Shumdit
    Shumdit Formula Junior
    May 9, 2006
    335
    Greenville, SC
    Matthew B.
    Someone keyed the top of your right qtr. panel or some odd birdcrap is on it :)
  21. jais
    jais Karting
    May 27, 2005
    175
    ATL
    I was browsing through some of the 430 pics on FChat and it seems to me that you will find the rear challenge on more non US cars. Is this just a coincidence?
    Let's see, 3,968 more posts until I hit 4,000!
  22. Tarek K.
    10,798
    Cairo - Egypt
    Tarek K.
    :D.........good luck.
  23. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Sam
    Tarek, you are the MASTER of Ferrarichat
  24. Fiorano1
    Fiorano1 Formula Junior
    Dec 7, 2004
    741
    Coral Springs, FL
    Haywood Jabloemi
    #24 Fiorano1, May 29, 2008
  25. ttforcefed
    ttforcefed F1 World Champ
    19,255
    #25 ttforcefed, May 30, 2008
