F430 Challenge Ceramic Brakes | FerrariChat
Discussion in '360/430' started by NexLevel, Aug 15, 2018.
  1. NexLevel
    NexLevel Karting
    Jul 10, 2018
    53
    Greg Thomas
    Guys,
    I know that 360 and F430 brakes are interchangeable but what about ceramic callipers and rotors from an F430 Challenge? Some websites that sell rotors states the challenge uses something different.
    Can anyone verify?
  2. cfensty
    cfensty Formula 3
    1,095
    South Carolina
    Minimum, you would need to change hubs (and wheels) over to center lock and switch master cylinders if I’m not mistaken.
  3. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Make sure the Challenge mounting studs come with the calipers; these sit 9mm further outboard to suit the 398mm discs (the Challenge uses standard F430 hubs with spaced calipers, whereas the Scuderia uses a unique hub with +9mm lugs, as below)
    The discs/rotors have a larger centre core to suit the Challenge hubs. I had some spigot rings machined to adapt to the F430 hub, as below. This was a quicker and easier approach than swapping the centre bells, which on anything over a 380mm disc means re-balancing of the finished assembly.
    Manda racing likes this.
  4. zipperkarting
    zipperkarting Formula Junior
    256
    Jersey & France
    paul troalic
    HI
    Just wondered where you got the spigot rings made? I am in France so I would not have a clue where to go. Is it possible you might be able to supply them to me.
    Paul
  5. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,005
    Cape Town South Afri
    Dave
    Great info , thanks
