F430 Clutch and Flywheel Service Costs? | FerrariChat
Discussion in '360/430' started by Zinger, Aug 4, 2012.
  1. Zinger
    Zinger Formula 3
    Apr 11, 2009
    1,894
    Leesburg, Va
    Ryan M
    What prices have you been paying for clutch and flyhwheel service on a F430 F1? I have heard the clutch itself is around $6000 but that the flywheel should be resurfaced or replaced "while in there"..... I have read/heard prices from $6000-$12,000 depending on what is needed/replaced while servicing these items. I would like to hear real prices not dealer markup, I searched the forum but found little information regarding specific pricing, please advise.
    My F430's clutch is around 45% worn so I am thinking ahead. I hope to get one more adjustment out of the clutch but I would like to replace the clutch/flywheel? at around 25% remaining, I dont like waiting till its fried to make a move, I get worried other components may be stressed.
    Thanks!
  2. Ferris Bueller
    Ferris Bueller Formula 3
    Mar 23, 2004
    1,863
    New Jersey
    Dominic
    Ryan,
    I know you are a big fan of Algar like me. Are you having them replace the clutch?
  3. Zinger
    Zinger Formula 3
    Apr 11, 2009
    1,894
    Leesburg, Va
    Ryan M
    I live 10 minutes from Ferrari of Washington who has provided great service to me thus far.
    I purchased my car at Algar and they have some of the best techs is the biz. I will
    certainly consider Algar for a extensive service like a clutch/flywheel etc...
  4. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    I was recently quoted $5400 in south FL.
    I say dont replace until it slips under hard load. I just dont see the benefit to changing early. Yes if its an F1 it could leave you "stranded" but I dont hear of that happening often.
    The main component that gets stressed when your clutch is "fried" is your wallet ;). You are more likely to need a resurface if you take it all the way down, but then again I "hear" that a high percentage of F430 clutch jobs need the resurface anyway. What I want to avoid is changing the clutch too often, so just like my tires, I will run it down, replace, then drive some more.
  5. big_guy
    big_guy F1 Rookie
    Sep 9, 2007
    3,190
    Ontario, Canada
    Sounds like sage advice to me.
    I have experienced too many times dealerships and indys recommending maintenance way before it is necessary. After all it is in their self-interest to do so.
  6. Zinger
    Zinger Formula 3
    Apr 11, 2009
    1,894
    Leesburg, Va
    Ryan M
    Trent,
    Was the $5400 price for just a clutch job? Is it true the flywheel needs resurfaced or replaced during a clutch replacement?
    My dealer says the flywheel is not reusable when removed due to a "bowl shape" the flywheel takes on from wear, heat etc...I know the dealer is obviously trying to push any and all items but is the flywheel a critical item to replace while in there?
    Ryan
  7. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    Flywheel not included @ $5400. I have read on fchat, recently, a tech stating it can be resurfaced. I have also read the contradiction. So I dont know.
  8. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    I agree. Replace when it slips under load. It has happened to me several times in the past. It is how I learned to shift without the clutch -- best way to teach you how to synchonize. :)
  9. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    ...and to learn how much it costs to replace the transmission :)
    On motorcycles (superbikes) with their aggressive synchros I always upshift without the clutch and can easily downshift without it as well, however downshifting is a bit more tricky to rev match and to be smooth. With a failed clutch on a Porsche I was able to rather quickly learn how to shift without the clutch, but it was clearly abusive to the system.
