430 - F430 clutch question….. | FerrariChat
430 F430 clutch question…..
Discussion in '360/430' started by JAMES MANSFIELD, May 6, 2023.
  1. JAMES MANSFIELD
    Feb 1, 2018
    37
    JAMES MANSFIELD
    I have a 2006 F430 with about 12,000 miles that I drive regularly. I took it out last weekend and it worked great.
    I backed it out of the garage this morning and it rev’d to 3000 before engaging the clutch. I pulled it forward and it rev’d to 3000 again without engaging the clutch, there was no smell of burning clutch and there’s been no indication of clutch slip prior to today.
    I had the ECU’s flashed. Is it possible that this put the PIS out of adjustment? Or do clutches on these just ‘go’?
    mechanically, I’ve never come across anything like this before on any vehicle.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,963
    Isle of man- uk
    Is the boot lid or front lid open, driver or passenger door open. It normally does not engage at all, let alone @3000. is it showing as engaged in 1st or reverse
  3. 24000rpm
    24000rpm F1 Rookie
    what is the distance that the clutch disc travels when it was released from fully engaged with the flywheel ?
