F430 converting from carbon to steel brakes question | FerrariChat
Discussion in 'Technical Q&A' started by Backitoff, Feb 7, 2024.
  1. Backitoff
    Backitoff Rookie
    Jun 25, 2016
    5
    Uk
    Allan
    Can I just replace my carbon rotors and pads for the steel equivalent? Or is there more to do?
    I'm swapping because I want to preserve the original discs.
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,949
    The Cold North
    Tom
    Just swap them. You will be ok..
  3. Backitoff
    Backitoff Rookie
    Jun 25, 2016
    5
    Uk
    Allan
    That's great to hear thank you. Just to confirm, it's as straight forward as remove Carbon discs and pads, and re fit with the steel equivalents?
    Thanks again
  4. eric355
    eric355 Formula 3
    1,225
    Toulouse (France)
    Eric DECOUX
    Note that your cluster will continue to record CCM wear.
    You will have a wear inconsistency when you reinstall them (cluster >> actual)
  5. windsock
    windsock Formula 3
    1,152
    Anyone with a Leonardo or equivalent can reconfigure the dash to steel brakes. I wouldn't worry about it to much until the wear indicator turns on in the dash.
