F430 Coupe Rear Window Moisture | FerrariChat
Discussion in '360/430' started by Jrosenthal, Sep 20, 2022.
  1. Jrosenthal
    Jrosenthal Rookie
    Nov 8, 2021
    10
    jonathan rosenthal
    Does anyone have a suggestion for fixing moisture that accumulates between the laminated pane window between drivers cockpit and engine compartment. Mine shows moisture when the engine heats up. When the engine is cool the moisture disappears.
  2. 2008F430
    2008F430 Karting
    Apr 30, 2020
    106
    St Augustine
    Are you sure it’s between the glass? If my AC vent is blowing directly on the back window I will sometimes see condensation on the window but not inside it.
  3. btshat
    btshat Karting
    Jun 10, 2021
    84
    Iowa
    Brian
    That happened to mine too. Seal has failed, as far as I know you will need to replace the glass. There is really no way to clean water spots between the panes. I had mine replaced.
  4. LorenzoR
    LorenzoR F1 Rookie
    Same happened to me. Looked liked bubbles between the glass. I had mine replaced. Not hard but the problem is getting the glass and especially the gasket/seal thats around the glass. I don't think its available any more
  5. btshat
    btshat Karting
    Jun 10, 2021
    84
    Iowa
    Brian
    The seal was available at ferrparts.com as of a couple of months ago. Glass is available there or direct thru Ferrari.
  6. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    I think eurospares has them. A friend had his rear blow out from a rock coming in and parts were available. This was a couple of months ago.
  7. Jrosenthal
    Jrosenthal Rookie
    Nov 8, 2021
    10
    jonathan rosenthal
    Thanks for all the feedback. The moisture is definitely in between the two layers of glass. I tried to wipe it off and no luck. You can find new rear windows from OEM for $1500 or out of salvage cars for $500. But that seems like a lot to fix an intermittent problem.
  8. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    Cant we just replace seal and reuse glass? Mine also has this issue
    So its not normal?
  9. LorenzoR
    LorenzoR F1 Rookie
    Well if you have bubbles between the glass then that's not going away. If I'm correct it's a 3 pane window glass and and it bubbles up and between. I really don't think it's moisture I think it's the plastic between the glass separating. That's what it appeared to be to me but maybe someone else might know but with that said you gotta replace the glass and and the seal. If one is very careful you can save the seal and reuse it
  10. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    Mine comes and goes, anyway
    Ive asked dealer to see if they can replace it all
    Makes sense!
  11. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    Anyone have source for seal in stock please??
  12. CoreyNJ
    CoreyNJ Formula 3
    2,446
    New Jersey Shore
    No one has this seal in stock. I have been looking for two years. We need enough people to request Ferrari for this part to make a new run or see if a 3rd party can recreate it.
    craze likes this.
  13. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    Wouldnt any window person have stock of a universal seal? What is special about it?
  14. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    Nobody is going to have that in stock.
    Just order it through Eurospares. 10 days to get it from ferrari and then express ship it. By the time you finish looking for the part in stock somewhere ....you would have already have.
  15. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    But apparently ferrari doesnt even have it
  16. CoreyNJ
    CoreyNJ Formula 3
    2,446
    New Jersey Shore
    I tried that already, here was their response...
    Part 63354600 is no longer available now. But I can still order part 69734700 at £544.71
    Flea7 likes this.
