F430 cracked headers | FerrariChat
Discussion in 'Ad Archives' started by RedTaxi, Dec 1, 2015.
  1. RedTaxi
    RedTaxi F1 Rookie
    3,338
    New Zealand
    Glen
    I am after a set of 430 headers cracked or not. I am wanting to re-tube a set and add a flexi bellows (as per 458) where the pre cat was. This will be a cost effective alternative to the expensive aftermarket headers. I can do mine but would rather swap them out so the car is not off the road as long. They need to be cheap as the freight to NZ will kill me.
    Regards, Glen
  2. RedTaxi
    RedTaxi F1 Rookie
    3,338
    New Zealand
    Glen
    There must be a mountain of these somewhere?
  3. Andrie
    Andrie Formula Junior
    Mar 6, 2015
    726
    Bay Area, CA
    Andrie Hartanto
    I installed headers on my F430 last weekend and reviewed the design. I agree with you, that the header and exhaust bracket failure is due to a non flex exhaust system. The engine with the header move as a unit, but the exhaust is tied to the chassis and move as another unit. Thus the difference of movement between the two causing the failure of the exhaust hanger and/or the header. Something got to give.
    I do have an idea on how to make the joint from the header to the cat flexible. The connection uses donut which should allow some movement if the spring loaded fastener was designed correctly. Lots of Japanese car uses this method. However, Ferrari solution with the fastener is flawed IMO. If you look at it, the spring acted as a tension for the fastener itself, sort of belleville washer. A flex-pipe would definitely fix it, but I don't think there is enough room, unless you weld the flex pipe on the cat pipe side.
  4. RedTaxi
    RedTaxi F1 Rookie
    3,338
    New Zealand
    Glen
    I think if I keep the primary pipes short and get rid of the pre-cat then there should be enough room for a flexi joint before the cat pipes. Yes, definitely the rigid design causes the failure. Ferrari have acknowledged this by adding a flexi joint on the next model 458. Interesting the 458 has no heat shields either. I think the metal shields may cause hot spots also. I believe insulating each pipe individually is a better way to go as it will insulate each pipe from each other.
    Still need some headers so I can have a play.
  5. RedTaxi
    RedTaxi F1 Rookie
    3,338
    New Zealand
    Glen
    Where are all the cracked headers?
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Dealers replaced them under warranty, try there.
  7. RedTaxi
    RedTaxi F1 Rookie
    3,338
    New Zealand
    Glen
    No emissions warranty over here. Our sole F-dealer repairs them. They may have replaced some under normal warranty though. I will ask, thanks.
  8. time
    time Formula Junior
    Sep 15, 2011
    511
    DeeGee
    I have a pair of 430 Challenge headers.. Not cracked.. PM me an offer if they will work for you. They can be cheap.
  9. kingp0820
    kingp0820 Rookie
    Dec 6, 2017
    30
    Castro Valley, CA
    Ramon Periquet Jr
    I have a pair of original headers from my 2007 F430. They both had cracks so I had them repaired as the cracks were at the welds, so the shield first comes off and then repaired then the shields get welded back. One is in perfect shape but on the other (R side) we tried to take away the pre cats inside which wasn't easy so that currently is broken unless its reopened. Happy to send you both for 300$ USD. I'm from the San Francisco Bay Area. Email me at [email protected] and I can send you pictures. Thanks
  10. RedTaxi
    RedTaxi F1 Rookie
    3,338
    New Zealand
    Glen
    Thanks but that was 10 years ago. I fitted challenge headers without the pre-cats so I'm all good.
    Willl likes this.
  11. koisokok
    koisokok F1 World Champ
    12,272
    nine 0 two one 0
    "so the car is not off the road as long"
    would of been an understatement ! ,.,:p
    RedTaxi likes this.
