F430 Crazy Grinding Noise Rear Left | FerrariChat
Discussion in '360/430' started by Daneuroman, May 19, 2014.
  1. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Western Massachusset
    Dan
    So My car has been sitting in the garage for the winter. I didnt have a battery maintainer on. I just left the battery unplugged. Battery was dead, tried charging it, wouldnt hold a charge. So I used another battery that seemed to have had 50 percent charge. I plugged it in, the lights came on, but wouldnt turn the car over. I figured I would jump it and it should do the trick. After hooking up three different jump packs at once I finally got it started. I was relieved.....Now it was time to go for a ride. I pulled out of the garage just fine. Started driving a bit in the driveway and heard from noise from the rear left, as if something as catching the tire. It got louder and louder. It got to the point where you could hear it down the street. Obviously the noise was only there when the car moved, either forward or backwards. It sounds like some internal gears are being grinded into metal shavings. Consequently the ediff light goes on, and then off and back on. The check engine light came on for a minute or two and went off. I made it back into my garage, went and bought a brand new battery and installed it. I figured oh its probably just because of the battery. Maybe it was just because of the battery, but now even though i installed the new battery its the same noise if not worse. Im just hoping I didnt screw up the ediff internally. So I honestly have no idea whats going on. If anyone has run into anything like this please help me out. I really hope I can get this back on the road without a visit to the dealer.
    Dan
    Thanks in advance.
  2. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Is your ebrake frozen?
  3. Cyphur01
    Cyphur01 Rookie
    Jan 23, 2012
    36
    Keller, TX
    Nick Johnson
    Ebrake caliber would be my guess as well. That would throw the diff into a tizzy as well.
  4. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I once made the mistake of setting my parking brake in the garage. Wouldn't move in reverse until it made horrible noises and jumped. The brake pads stick to the rotors. Now I just leave it in first gear and no parking brake -- plus I don't get that beeping noise.
    Alan
  5. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    I thought it might have been the ebrake as well. But I noticed the noise gets worse when making turns. I'm going to make a video and post it up. You can literally hear the noise down the street.
  6. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Can you push the car forward or back when in neutral?
  7. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    Yeah. At one point I was afraid to keep driving it, so I put it into neutral, and just pushed it with my friend. It still made the same noise even in neutral.
  8. montsd
    montsd Rookie
    Feb 10, 2014
    9
    San Clemente
    Mikey
    My car made a similar noise (07 F430) - grinding sound out of the rear differential and would get louder when turning sharp in a cul de sac and would go away after about a mile or so. Took it to my shop and they changed out the differential fluid and problem never came back. He told me this is common when cars sit for a while.
    Sent from my iPhone using Tapatalk - now Free
  9. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    Wow, just because of the diff fluid?
  10. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,861
    San Jose, California
    Ha ha this reminds me of a hilarious story from when I was young and stupid (now I am just old and stupid). :)
    I had to replace the third member (differential) for some reason in my Toyota Corolla during my college days. I yanked one out of a similar car at Pick n Pull (thank goodness I purchased the warranty), threw it in my car, then took off down the freeway. One slight goof: I forgot to put the gear oil back in.
    So I'm flying down the freeway when I thought I heard a funny noise coming out of the rear end. I hear a click. Then a click, then a louder click, then a thunk, then a louder thunk, then a chunk, and then (at 70 MPH) the rear end instantly and completely locks up! So now I am sliding down the freeway, thinking WTF??????????
    So I yank that one out, bring it back to Pick n Pull, tell them I don't like that one, yank another one out, put the gear oil back in this time, works perfect.
    :D
  11. Daneuroman
    Daneuroman Rookie
    Oct 24, 2013
    28
    Dan
    LOL! Thats Hilarious.
  12. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,203
    Beverly Hills, CA
    Jay
    wheel bearing
  13. Forcefed
    Forcefed Karting
    Aug 14, 2009
    203
    United Arab Emirates
    I have a similar grinding noise but coming from the front wheel well and only when going in reverse slowly and the wheel slightly turned. If i pick up in speed the sound disappears.
    Any thoughts on what is the cause?
    Thank you.
  14. Forcefed
    Forcefed Karting
    Aug 14, 2009
    203
    any ideas about front end grinding?
