430 - F430 Diffuser and Engine Bay Panel Spray Paint | FerrariChat
430 F430 Diffuser and Engine Bay Panel Spray Paint
Discussion in '360/430' started by JM280z, Aug 18, 2023.
  1. JM280z
    JM280z Formula Junior
    Aug 22, 2020
    878
    Jake
    Hey All,
    This paint matches perfectly, I mean perfectly….. remember, paint work is all about prep work and patience. If you paint your own, make sure to have proper steps of sandpaper, clean it very well, wait for the perfect day (no wind and temp and humidity) and take your time with many thin coats.
  2. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,773
    Caveat: if you have black trim. Grigio Silverstone has black and presumably Nero, but most have metallic grey.
    JM280z likes this.
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    I had some paint mixed to code 236430, chomo grigio corsa met, but it is just not right. Too silvery. . This was a code from a thread on here. Awaiting info from factory.
  4. JM280z
    Aug 22, 2020
    878
    Jake
    I didn’t know this! My friends F430 is red and mine is grey, so we have both used this paint.
  5. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,773
    That's interesting. Red should have grey :)
  6. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,773
    There's a problem at the moment, Mike. I had the same experience and didn't get to the bottom of it. Previously the paint had been a perfect match out of the tin. I ended up mixing my own Grigio Corsa using a blend of Vauxhall greys.
    It's possible that there has been a rationalisation of the paints because some shades of Rosso Corsa have disappeared from the PPG range. Very strange.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    I think the parts list has 2 colour options
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    You assume that the paint mixing machine is calibrated ok. Taking ages to get the details from the factory
  9. CoreyNJ
    CoreyNJ Formula 3
    2,439
    New Jersey Shore
    You can have a regular body shop just mix up touch up matched to the panel and some matte clear. Before I switched to Carbon Fiber engine panels I had one of my panels repainted because it bubbled from the heat. They gave me some extra touch up at the same time.
  10. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    I just got the info from the factory, if you have the silver version it is paint code 236430. Croma grigio corsa
  12. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,773
    Thanks Mike, that's the one. A recent job with that paint was too silver. Didn't get to the bottom of it after multiple attempts at new mixes. Previous orders were spot-on.
