F430 e-diff bleed | Page 2 | FerrariChat
F430 e-diff bleed
Discussion in '360/430' started by Hacan, Apr 23, 2019.
  1. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,812
    Central NJ
    Dominick
    I don't see e bleed .. like I mentioned before I don't believe it has the function ...
    Sent from my moto g(7) using Tapatalk
  2. mechanicservice6
    71
    Sorry I thought clutch bleed was the same.
    Sent from my LM-G850 using Tapatalk
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,812
    Central NJ
    Dominick
    Not sure if you were the one with the inside track to launch ..maybe you can suggest to add "communication to electronic diff ecu with activations" to program ?
    If it wasn't you . Sorry in advance
  4. Ferrari1221
    Ferrari1221 Karting
    Jan 14, 2017
    65
    I am guessing here as when I selected the 301 on my Auto Enginuity Tool, it would not read battery voltage or hydraulic system pressure correctly. But selecting 201 it does. So I assumed 301 was perhaps for the Scudiera TCU and had nothing to do with Diff? Can anyone verify?
  5. GogglesPisano
    GogglesPisano F1 Rookie
    3,143
    East Bay, California
    Joe
    At the stage where we need to bleed the E-Diff for my manual conversion. Would this process still apply? I have a friend loading me a Leonardo but not until next week as the shop only has a Snap On Triton scanner and the Auto Maxisys Ultra.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,812
    Central NJ
    Dominick
    #31 flash32, Jul 11, 2024
    Yes the process still applies but the great thing is Launch has added it to it line-up including the thinkdiag (2) as well
    Also you don't depending on ECU version you don't have to start engine just key on to perform bleed
    Pretty straight forward - easier that a one wheel brake bleed
    Just be careful not to run dry
    Call me.anytime with any questions
    oc23, mwstewart and GogglesPisano like this.
