F430 Engine bay open | FerrariChat
Discussion in 'Technical Q&A' started by fga4, Jun 27, 2018.
  1. fga4
    fga4 Karting
    Jan 2, 2017
    119
    SF Bay Area
    Jerry Cellilo
    Took off the interior side panels to gain access to replace spark plugs and wondering if there is anything else I could/should do while I have access to the engine.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    I would consider as I am doing ..some heat resist backing .. the one that looks like aluminum paper on thin foam .. I was thinking of putting in the panel itself
    Just a thought
    Sent from my Moto G (4) using Tapatalk
  3. Sled Driver
    Sled Driver Formula Junior
    May 13, 2010
    494
    Stokesdale, NC
    Emery
    As long as you mechanically attach it ( pop rivets or screws) it shouldn't be an issue.
    I installed one on the back side of the air box to insulate it from the exhaust.
    I realize it has minimal effect with the velocity of the air through the box, but it was more for heat soak of the box itself.
    I also have one attached to the engine compartment hatch (Hood) above the muffler. Both are attached with either screws or pop rivets.
    The adhesive backed (peel & stick) heat shields are to be avoided. Depending on the proximity to a high heat source (headers, cats, muffler) there is a risk of the adhesive catching fire. Or due to the adhesive breaking down with age/heat cycles become dislodged & contact a heat source, catching fire.
    This was the issue with early 458's burning up & was addressed by dealers replacing those heat shields.
  4. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    This was the issue with early 458's burning up & was addressed by dealers replacing those heat shields.[/QUOTE]
    I have used a lot of the aftermarket adhesive backed foil type insulation and I can tell you, they do not catch fire. Ferrari just messed up when they glued there panels on.
    I have had that stuff turn black from heat and still no fire. The gold stuff is better than the silver. Works well.
    Here is a link to stuff I have used on a Trans Am & a 308 road race car:
    https://www.summitracing.com/parts/hsp-707016/overview/
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    Based on discussions above I may change the material I am using to the hd lava shield ..
