F430 Engine Damage | FerrariChat
F430 Engine Damage
Discussion in '360/430' started by sal123, Jul 26, 2009.
  1. sal123
    sal123 Rookie
    Dec 1, 2008
    33
    Hi Guys
    Has anyone had any engine damage on their F430.
    I am currenlty dissmantling an engine with damage to the top of 2 pistons.
    Something has got into the engine but i dont know how.
    Thanks in advance for any response
  2. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    Could it be "pre-cat" from the headers??? Sucked back into the engine....
    Happens on the 360's on occassion..
  3. sal123
    sal123 Rookie
    Dec 1, 2008
    33
    yes , i have heard that but i have been lucky enough to NOT see it
  4. PAP 348
    Dec 10, 2005
    100,200
    Mount Isa, Australia
    Pap
    Can you post some pics of the damaged pistons?? :):)
    Wouldnt mind seeing what sort of damage happened. :):)
  5. Ricambi America
    Sponsor Owner
    #5 Ricambi America, Jul 27, 2009
    We've sold F430 pistons, liners, and assorted bits lots of times... all for one reason: manifolds.
  6. Miner_31
    Miner_31 Formula Junior
    Jun 27, 2008
    376
    Summerfield, NC
    Its not common in the F430 but like previously stated the manifolds were to blame. I have also seen one have issues that was overfilled with oil.
    What do you mean something got in the engine?
  7. sal123
    sal123 Rookie
    Dec 1, 2008
    33
    #7 sal123, Jul 27, 2009
    Thanks Daniel,
    I think you just got another order from Australia.
    Here are a couple of pictures of the damage,
    There could have been alot more
  8. Rifledriver
    36,819
    A foerign object made it into the cylinder and it was probably steel. I have seen many pistons damaged from cat converter matrix material and it is very different.
  9. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,839
    #9 MalibuGuy, Jul 27, 2009
    I have a question regarding "backpressure" from the 430 muffler.
    Do you think it is safer to have the exhaust valves pinned open as this reduces backpressure?
    Owners of CS and F430 and some 360 with the factory sport stradale do pin open the valves for better exhaust notes. But maybe there is a benefit if this helps reduce the pressure that might blow the cat converter matrix backwards into the cylinder?
  10. SonomaRik
    SonomaRik F1 Veteran
    #10 SonomaRik, Jul 27, 2009
    what type of steel would make it into there, and wouldn't it be tiny and often to cause that kind of damage?
  11. PAP 348
    Dec 10, 2005
    100,200
    Pap
    :eek::eek:
    Thanks for putting me off buying a 360/430 Brian! :D:D
  12. Rifledriver
    36,819
    Wouldn't keep me from buying one. I have never ever seen a stock 360 kept in good running condition eat its cat.
  13. Rifledriver
    36,819
    Without doubt the best thing you can do is leave it the way Ferrari built it. Backpressure does not cause that.
  14. carcommander
    carcommander Formula 3
    Sep 28, 2006
    1,705
    Southeast
    Jim
    +1 modifing a Ferrari is frought with peril.....to your wallet.
  15. mgv1
    mgv1 Formula Junior
    Feb 6, 2006
    496
    San Francisco
    Mark V
    Is the metal tip of the spark plug still attached. I had a similar looking problem with a jaguar engine once. Wrong plug temp selection or detonation can cause the plug to breakdown and shed components.
  16. PAP 348
    Dec 10, 2005
    100,200
    Pap
    Very good sir!! Cause I am QUITE partial to a CS or a 430. :eek::eek:
  17. MalibuGuy
    Sep 18, 2007
    5,839
    Thasnks for your advice. Will do!
  18. bobby355
    bobby355 Karting
    May 21, 2009
    244
    Are you able to ever spot back pressure? does it make a specific sound of some sort? How do you find out whether this is happening or not?
    Thx.
    Bobby
