F430 exhaust valve questions | FerrariChat
Discussion in '360/430' started by aslowdodge, Oct 17, 2019.
  1. aslowdodge
    aslowdodge Karting
    Jun 5, 2004
    206
    Marietta, Georgia
    i have a stock exhaust manifolds with a tubi muffler. The previous owner removed the exhaust valves. While the sound is pretty cool, the noise level gets very tiring going down the freeway. For those that have the valves, is it closed during cruising down the freeway? If not, is it harmful to get a manual control and close the exhaust valve at freeway speeds?
    I see exhaust valves on eBay, would those work?
  2. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    Youtuber Normal guy Supercar installed aftermarket exhaust valves on his car. They kept breaking. Look him up on YouTube and search for his videos, it’s probably been 2 years since he posted about the valves. Caveat emptor.
    Sent from my iPad using Tapatalk Pro
    f355spider likes this.
  3. ttforcefed
    ttforcefed F1 World Champ
    19,256
    did he remove them or just disconnect them? if they were removed, that sucks unfort. the open or close depends on how much throttle ur giving it - so if ur cruising at speed on the freeway and low rpms they are closed...
    Skidkid likes this.
  4. cfensty
    cfensty Formula 3
    1,095
    South Carolina
    Likely just disconnected and need the hoses reconnected.
    DOWORKFCAR likes this.
  5. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Santa Barbara County
    Sam
    When mine were connected they would open at 4k rpms
    Sent from my SM-G975U using Tapatalk
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    If he removed the valves he would have had to weld a pipe section in its place- if removed then look on e bay for a used set of pipes and swap them.
    More likely he has just plugged the hoses, just reconnect them
  7. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    The YouTuber is a good example of what NOT to do.
  8. aslowdodge
    aslowdodge Karting
    Jun 5, 2004
    206
    Marietta, Georgia
    The valves are definitely gone. I wish they were only disconnected. While cruising at 80mph it’s probably at 4000 rpm and kind of too loud to just cruise at a length of time.
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Common and cheap on e bay
  10. ttforcefed
    19,256
    Tubi has 2 exhausts - one with valves and one without. You have one without it sounds like.
  11. aslowdodge
    aslowdodge Karting
    Jun 5, 2004
    206
    Marietta, Georgia
    Yup. Trying to figure out a way to put valves back on somehow.
  12. ttforcefed
    19,256
    Sell what u have and get a new tubi
