F430 F1 gearbox failure | FerrariChat
Discussion in '360/430' started by clk20000, Apr 14, 2018.
  1. clk20000
    clk20000 Rookie
    Dec 8, 2012
    13
    Hello Friends:
    My name is Pool and I'm from Spain.
    I've many problems with my f430, after driving it 3-5 kms F1 fails and go to N, the gears doesn't respond, nothing change if you turn on turn of, then if I wait 2-3 hours the car runs again.
    Fail in memory are P1742 selectin potenciometer, P1735 self powering relay driver, P1770 gear engagements with wrong shifts, p1781 relay drive pump stuck or pump pilotage relays stucked.
    Any info about fix it?
    regards
  2. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,773
    First change the F1 relay. It has likely failed or if you are unlucky the pump motor is wearing which is overloading the relay.
    Try the relay first and see how you go - there may be another issue to sort but start with the basics.
  3. clk20000
    clk20000 Rookie
    Dec 8, 2012
    13
    do you speak about relay behind driver's seat?
  4. RichardCH
    RichardCH F1 Rookie
    4,661
    Yep sounds like F1 pump mine went last year
    of2worlds likes this.
  5. tazandjan
    39,159
    Take her to someone with an SD3 and have them diagnose the problem before throwing parts at her. Could be she just needs an F1 service and self test accomplished. They will change the F1 fluid, bleed the system, check for leaks, and run the self-test sequence. If she still has a problem, they can fix that when they know what it is for sure.
    whatheheck likes this.
  6. clk20000
    clk20000 Rookie
    Dec 8, 2012
    13
    Continous with the problem.
    The symtomp's are these:
    Car runs ok for 10 minutes or about 100º temp.
    then go to N
    Sometimes waiting 4-5 minutes runs again, I can heard pump working and actuator trying to insert the gears but no result.
    Many times when is cold is very hard to insert reverse.
    Codes: P1741 Engament potenciometer, P1772 Opposite engament other times with P1742 Selection Potenciometer and P1770 Gear Engagements with Wrong shifts
    I already upgraded f1 pump and relay, also I have made purge and self learning.
    Any idea to fix it.
    regards
  7. LorenzoR
    LorenzoR F1 Rookie
    sounds like to me that you have an actuator problem. but id do like others say and get it hooked up to a SD3
  8. 993man
    993man Formula Junior
    877
    New Zealand
    Graham
    I was driving down the road when I owned a 360 F1 and it went into neutral, but unlike yours, mine wouldn't go into gear.
    It was towed home and I diagnosed the fault (thru this site :) to be that little pump/motor that charges the F1 pump or something.
    It's in the right hand side under the cover. Easy to get at. If you open your drivers door you will hear a noise right? That should last a few seconds only. Mine went on for like 30 seconds which was the sign it was poked.
    Ferrari wanted $3000NZ for one, but I used one from a Alfa which is the identical part and cost $900.00. Go figure.
    I was chuffed that I fixed it myself though.
  9. clk20000
    clk20000 Rookie
    Dec 8, 2012
    13
    Pump motor is already changed
  10. magic
    magic Formula Junior
    Nov 2, 2004
    512
    London
    Hi
    I had a similar issue for five years. Changed the clutch 3 times, relay, pump, hydraulic fluid reservoir.
    We then did a part by part assessment. Luckily the owner of the garage also had a 360 f1 that he was prepared to let us use parts from his personal car.
    Firstly we changed the clutch, release bearing and put in all new parts as the clutch has become warped. None of that worked !
    The car only does it when its running warm/hot correct ?
    The answer was the solenoids !! We used his unit and the car has been perfect since in traffic and hasn’t fallen into neutral in 5 months !
    It was a pain and tool several weeks to get to the bottom of the issue.
    If you want you can call the owner of the garage his name is Ash and the garage is http://scuderiascaglieti.com/
    Tell him that Maz give you his details.
    Good luck !
  11. Skidkid
    Skidkid F1 Veteran
    9,518
    Campbell, CA
    John Zornes
    +1 but they never listen.
    Rifledriver likes this.
  12. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    But they’ll take their crappy Toyota Camry to a mechanic every time for service and repair.[emoji849]
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,773
    It seems the pump and relay swap fixed the pressure issue, which is good, but for the remaining issues take the advice above. There are a number of potential causes for the remaining codes and diagnosis is best performed in person.
  14. Stout
    Stout Formula Junior
    May 9, 2013
    259
    Helotes, TX
    Victor
  15. ShadowF430
    ShadowF430 Formula Junior
    Mar 29, 2017
    270
    Portland
    Jason
    I had an issue once but thankfully it threw a code. F1 light and engine light on. Towed to ferrari, they bleed it still showed a problem so replaced the 2 potiemeters (not sure if that’s how it is spelled). They ran their computer on it and good as new. If your f1 actuator is failing, a company called GTE engineering rebuilds for much less than the outrageous price Ferrari charges.
    gonigon and Mjhillz like this.
  16. clk20000
    clk20000 Rookie
    Dec 8, 2012
    13
    I already change the 2 potenciometers but not result, same problem, now I've not codes on diagnostic,
  17. Skidkid
    Skidkid F1 Veteran
    9,518
    Campbell, CA
    John Zornes
    You had to shut off the power to change the potentiometers so it isn't a surprise that there are no more codes. You really needed a reading from an SD BEFORE you did a power cycle. See post #5 and #11. Right now you are just throwing parts at this and hoping for a change.
  18. clk20000
    clk20000 Rookie
    Dec 8, 2012
    13
    I already diganostic with x431 no faults in gearbox, yesterday before stop it, car shows E-diff failure, May be a problem with e-diff valve or f1 acumulator?
    Things tested:
    New f1 pump
    Potenciometers
    Bleed f1 and clucth
  19. FSM348
    FSM348 Formula Junior
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    Did this problem get fixed. If so, please add results. It’s appreciated when asking for help that the fix is posted by OP. Thanks.
  20. gonigon
    gonigon Rookie
    Aug 11, 2022
    15
    Galicia, Spain
    Gonzalo
    Hello ShadowF430, do you remember if the code was "P1742"? Did the 2 potentiometers fail with the diagnosis? Thank you for your reply
  21. Rifledriver
    37,082
    F1 system is easily diagnosed with the proper equipment and a good understanding of how to use it.
    The other alternative is to go on the internet and ask for advice. That leads to well intentioned guesses, throwing parts at the problem, unsatisfactory results and an unreliable car.
    Just sounds like an easy decision to me but by all means do it your way.
  22. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,890
    Central NJ
    Dominick
    As you said the F1 isn't that complex to diagnosis if you know what you are doing ... unfortunately I have found many "mechanics" at dealers or indies just don't have the skills. I have helped a number people in this forum that were being charged for parts and labor they didn't need.
    Had one person being asked to authorize 12k for a full new power until etc when all he needed was an accumulator and one solenoid
    Crazy !
  23. swc5150
    swc5150 Formula Junior
    721
    Wisconsin
    Scott Calderwood
    Agreed, don't just toss parts/money a it. Find someone who really knows what they're doing to help. For every @flash32 (F1 Jedi Master) there are two dozen morons that will "diagnose" your system into a money pit.
    flash32 likes this.
  24. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,890
    Central NJ
    Dominick
    Scott
    I was never called that ..but love it..thank you
    I will help anyone I can as long as they can wrench and have the proper tools
    swc5150 likes this.
  25. Rifledriver
    37,082
    I agree but the smart alternative is not the internet guessing game. There are bad lawyers, doctors, plumbers and mechanics. The cure is to get off your lazy butt and get a good one.
    flash32 likes this.
