F430 F1 Gearbox Not shifting past 2nd, CAN BUS wiring diagrams. | FerrariChat
Discussion in '360/430' started by amylesw, Aug 19, 2024.
  1. amylesw
    amylesw Rookie
    Aug 2, 2024
    3
    alexander myles watson
    I am working on a 2006 Ferrari F430. It first presented with a no start condition. I diagnosed that as a bad immobilizer unit. Had that deleted/Bypassed in the ECU's. Now when driving I get a few warnings in the instrument cluster and it will not upshift to 3rd. I can shift into neutral and upshift to 6th and downshift normally. Multiple CANBUS faults. I would love to find some CANBUS wiring diagrams to help me continue to diagnose. Warnings in instrument cluster are for suspension and ediff. The driving mode will only select snow or slippery.
  2. Qavion
    Qavion F1 World Champ
    14,639
    Ian Riddell
    XA, YA, XR, etc, are inline connectors. The diagram is for a Scud, but should be close enough.
    I believe CAN Bus problems can be caused by faulty devices (ECUs, etc) or inter-ECU wiring issues. Not sure how you'd go about figuring what is causing your issues. Maybe best to seek professional help (guys with specialist equipment)
    Did you bend any pins reinstalling plugs during the delete/bypass?
    Willl likes this.
  3. amylesw
    amylesw Rookie
    Aug 2, 2024
    3
    This will definitely be helpful, thank you @Qavion. I will be going through the connections first.
    Qavion likes this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,200
    Central NJ
    Dominick
    If the F1 system including the ediff is of suspect..I would spend my energy looking at F1 pressures and timings ..
    If you want to chat send me a PM
    I think it may be quicker than trying to figure out some of the ghost CAN messages
  5. tazandjan
    39,392
    Odds are it is a bad F1 solenoid, like Dominick said. Proper analysis with an SD3 or equivalent will tell you the answer. Mine had the same symptoms of not shifting past 2nd and it was a solenoid.
  6. robst
    robst Karting
    Mar 9, 2024
    119
    Houston
    Rob
    following to see troubleshooting steps and final diagnosis
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,200
    Central NJ
    Dominick
    OP
    Did you resolve your issue ?
    My offer to help still stands
  8. amylesw
    amylesw Rookie
    Aug 2, 2024
    3
    Sorry for the delay, shop has been busy. Due to the CANBUS faults I had present. Which were;
    Transmission:
    P0600 in transmission module
    Steering Wheel System:
    U1602 CAN message reception fault - B status NFR - no signal
    U1605 CAN message reception fault - B status NCD - no signal
    U1607 NFR fault - B status NFR - set fail bit - ECU fault
    Instrument Cluster:
    B1005 Suspensions failure
    U1605 No CAN message from differential ECU received
    I started by checking what I thought were the relevant fuses for every module on the CANBUS. Then I unplugged and checked the connection at every module on the CANBUS. Then I decided to check EVERY fuse in the car. Then I found PSF5, a 7.5amp fuse located in the left hand side fuse box behind the driver seat was broken. Replaced the fuse and everything is happy. Thank you everybody for the assistance, thankfully it was an easy on after all.
    I am still in need of finding a sort of maintenance information as far as what to do when or any service information. This is the first and only Ferrari I work on and would love to find a good source of service information for future use.
    Qavion likes this.
  9. Qavion
    14,639
    Ian Riddell
    WOW.. great find. PSF5 powers the e-Diff and Suspension ECU, but perhaps more seriously, also sends power to the alternator regulator, too. Would this cause voltage regulation issues? (overvoltage/undervoltage).
    If it happens again, I would be checking the alternator wiring.
  10. Qavion
    14,639
    Ian Riddell
    You can usually find pdf Workshop Manuals online at relatively cheap prices (although a lot of sub-chapters are missing). Wiring diagrams are a different matter. They are hard to find, very expensive, incomplete, full of errors and are sometimes hard to follow. I've tried to convert some of them into more user-friendly diagrams, but the larger ones can be quite intimidating at first glance. Here's my E-diff diagram (a work in progress like the rest of my diagrams):
    https://www.dropbox.com/t/B3IFEyMmyKWKy0fq
  11. robst
    robst Karting
    Mar 9, 2024
    119
    Houston
    Rob
    You actually touch on a very good point. I've been trying to find shop manual for the F430, but have been unsuccessful, do you have any leads?
  12. Qavion
    14,639
    Ian Riddell
    robst likes this.
  13. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    23
    Carlos guerra
    Hi i have a F430 and have tried and checked everything that i have imagine reading in several posts, i have cluster with no gear N light, cst, e diff, suspension, tpms,abs, i have right now borrowed a SD3 but i am no expert just can get codes etc it have codes in cluster b1005 suspension failure already test solenoids and good also wheel sensors, b100c brake failure, u1602 no can from f1 gearbox, u1604 no can from tpms ecu.
    I am overseas with no ferrari etc here so i can pay in case for guidance to solve the problem my email is [email protected] please some help!!!! Many blessings
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,200
    Central NJ
    Dominick
    Make sure battery is fully charged and tested to be good ...then wipe out codes and see if they return ..if they do post here
  15. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    23
    Carlos guerra
    Hi i just checked battery since it is new it reads 12.76 and car on with lights and ac 14.2 i erased codes and they say present and cannot erase, wich are on cluster b1005 suspension failure, b100c brake failure,u1602 no can message recieved from f1 gearbox, u1604 no can message recieved from tpms ecu, on suspension U1706 no communication with NFR, on ediff C2006 Pressure sensor, C2007 Pump relay connection both present, abs C1103 configuration eol change
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,200
    Central NJ
    Dominick
    see if you get wheel speed on each wheel on diag tool
  17. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    23
    Carlos guerra
    Yes i did the wheel speed and all sensors where ok, i also did suspension solenoid test and all where good, i was looking on the SD3, do you know what is the pressure sensor because i feel the clutch when it goes out of 1st it does like you would take clutch put and if you dont acelerate quickly it shuts off like i would not shift good on a manual
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,200
    Central NJ
    Dominick
    also tell us when and how error came up .. out of no where , changed ABS ECU ?>
  19. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,200
    Central NJ
    Dominick
    Where are you located ? Time zone ?
  20. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    23
    Carlos guerra
    ImCar was good no lights in dash gear diaplay ok everything working but had a right fuel pump bad with a 15 fuse bad and we replaced that, we also replaced the 2 rubbers on the rear axle, and replace aluminum block plate of f1, after that started the car and all the light lighted up and no gear display
  21. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    23
    Carlos guerra
    I am in central america 6:39 pm in el salvador
  22. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,200
    Central NJ
    Dominick
    what is a aluminum block plate
  23. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    23
    Carlos guerra
    Rare thing before clutch had 16% used at 20.98 mm new closed clutch position and now it has new closed clutch position 22.29 mm -2%
