F430 F1 Gearbox Not shifting past 2nd, CAN BUS wiring diagrams. | Page 2 | FerrariChat
Discussion in '360/430' started by amylesw, Aug 19, 2024.
  1. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    18
    Carlos guerra
    This is the block plate, them we did a bleed of it and also we bleed the actuators and i changed potenciometer sensors thinking that maybe it was that
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,192
    Central NJ
    Dominick
    did you bleed e-diff
  3. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    18
    Carlos guerra
    Had not bleed it put i tried with a launch and it did not bleed, then i put power to the solenoid and i did bleed it like that, with the sd3 i put ediff bleed and it did got a little of fluid like the line had 0.60 cm filled
  4. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    18
    Carlos guerra
    The most rare thing is that i think when the mechanic put a autel scanner in the car and reset codes or i dont know what and i heard a beep and saw all lights
  5. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    18
    Carlos guerra
    But the guy said that the lights he saw they where already there so not 100% sure
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,192
    Central NJ
    Dominick
    At this point ..I am thinking you need to make sure clutch, actuator and E-diff are bled properly
    Need to also test E-diff solenoid by activating bleed function (try with engine on and off ) and see if the locking pressure goes up ...also time the pump cycles while you have bleed function activated (without bleed valve open) ..it should be more than a min
  7. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    18
    Carlos guerra
    Thank you Flash 32, how do i see the locking pressure? So when bleed function is ON i should hear the f1 pump going ON automatically every minute? The hydraulic circuit pressure is 51 bar.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,192
    Central NJ
    Dominick
    Use the Sd3 and go into the E-diff ECU
    Yes the pump should come on and off
  9. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    18
    Carlos guerra
    Ohhh ok because it does not come On when i give ediff pump on, i put pump on and recieved signal on the ediff sensor but nothing happened early morning.
  10. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    18
    Carlos guerra
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,192
    Central NJ
    Dominick
    Disconnect E-diff solenoid (not sensor) and see if things change ..still will give error but should be different
  12. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    18
    Carlos guerra
    Yes did that and it did gave me a solenoid code
  13. Shgcoffee
    Shgcoffee Rookie
    Oct 12, 2025
    18
    Carlos guerra
    Connect it back and it did clear that code
