430 - F430 F1 Going in for a new clutch today | Page 2 | FerrariChat
430 F430 F1 Going in for a new clutch today
Discussion in '360/430' started by cfensty, Jul 2, 2019.
  1. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    513
    Sweden
    The OE part number is 71751195.
  2. Jgivoo
    Jgivoo Formula Junior
    436
    New Jersey
  3. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,753
    England
    Mark
    Superb. Thank you.
  4. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    You're welcome! Always happy to help.
    Additional info: Hold the gas pedal DURING shifting. Once F1 is done shifting to your target gear you can then modulate the gas pedal to your desired speed.
    Dan
    Sent from my SM-G950U using Tapatalk
  5. cfensty
    cfensty Formula 3
    1,094
    South Carolina
  6. cfensty
    cfensty Formula 3
    1,094
    South Carolina
  7. BAD430BENZ
    BAD430BENZ Formula Junior
    May 13, 2014
    709
    EL PASO , TX
    JASON
    I paid around $5k for my complete transmission overhaul . Just got it back about a week ago and what an improvement !
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,685
    Central NJ
    Dominick
    What did that include?
    Sent from my moto g(7) using Tapatalk
  9. BAD430BENZ
    May 13, 2014
    709
    EL PASO , TX
    JASON
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,685
    Central NJ
    Dominick
    Thanks .. pretty good price to replace / rebuild clutch
  11. cfensty
    cfensty Formula 3
    1,094
    South Carolina
    JaguarXJ6 likes this.
  12. Jgivoo
    436
    New Jersey
    Was this done on a flywheel refinishing machine? Finish looks as though it was done on a lathe type machine. Just curious.
    That said, as long as the finish is flat and clean, it will be fine.
  13. cfensty
    cfensty Formula 3
    1,094
    South Carolina
  14. bradyorlando456MGTA
    Mar 31, 2014
    46
    Bluffton, SC
    Brady Orlando
    It ended up being machined on a lathe because a standard flywheel grinder can't get into the radius sharp enough on the outer edge of the wear surface or the radius of the pressure plate mounting surface. A standard flywheel grinder leaves a rounded radius and it wouldn't allow the pressure plate to sit flat, the same for the clutch disc. I just put the flywheel on the crankshaft with a dial indicator and the runout was 0.0005 in at the highest point. I'd say they did a very good job.
  15. cfensty
    cfensty Formula 3
    1,094
    South Carolina
  16. 328gts1987
    328gts1987 F1 World Champ
    Mar 11, 2007
    13,009
    Rotterdam Holland
    Fred
    Replacement (=original ferrari parts) fly-wheel, clutch, bearing, sensor etc (after 65.000km's/40.000 miles) in Holland € 6000,- including 21% VAT and Labour. Done by specialist, not dealer.
    After 1000km's reset the settings/re-program the clutch-pickup as plates/flywheel are worn into eachother. Makes a uge difference in (future)wear and comfort. This re-programm I never read about, was included.
  17. cfensty
    cfensty Formula 3
    1,094
    South Carolina
    Thank you. Definitely will have adjustment made after break in. Any advice on how to bed or break it in properly? Any specific procedure or just take it easy for a few hundred miles?
  18. 328gts1987
    Mar 11, 2007
    13,009
    Rotterdam Holland
    Fred
    #45 328gts1987, Jul 20, 2019
    Just drive as usual, no procedure (I am not told) Just re-programm to setting you like most. You must drive the car yourself during this setting. When you have found the sweetspot test al settings on steering wheel & reverse.
    Note:
    The re-programming is setting the distance/delay of engaging. Be aware that a tight setting can cause reverse engaging issues. My setting (personal) was just above that minimum.
    It picks-up perfect when leaving the line and shifts without slip
  19. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
  20. cfensty
    cfensty Formula 3
    1,094
    South Carolina
  21. cfensty
    cfensty Formula 3
    1,094
    South Carolina
    So after some summer vacations and then some Challenge race team traveling for Brady, he was able to get the clutch installed and the car back together. Test drive went very well and I am looking forward to picking the car up tomorrow or Wednesday! Image Unavailable, Please Login
    brookliner7 likes this.
  22. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,724
    Just East of Weird
    Bob
    After my clutch was replaced in June, I found the upshifts perfect but the downshifts, particularly from 3 to 2 was clunky and not normal. Had the dealer adjust the downshifts and now they are like butter. So make sure you check operation to make sure it’s to your liking.
    Sent from my iPad using Tapatalk Pro
    328gts1987 likes this.
  23. 328gts1987
    Mar 11, 2007
    13,009
    Rotterdam Holland
    Fred
    @cfensty
    How does it go? Happy? Any details on your costs?
