F430 F1 selection of nutral gear problem | FerrariChat
Discussion in 'Technical Q&A' started by wlracing, Jan 2, 2013.
  1. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Posted in 360/430 section , any one have problem selecting nutral before starting ? loud clicking from gearbox before finnaly staying in nutral ?
  2. tazandjan
    39,273
    Wally- Lots of things that could cause that problem with an F1 car, so probably best to let someone look at her with an SD3 before it gets any worse. As an owner you can check F1 fluid level, also shared with the E-diff, and see if that is low, but for anything else, you are going to need professional help and an SD3 or equivalent.
  3. wlracing
    wlracing Karting
    Dec 14, 2004
    234
    wally
    Car has been with dealer for third time with SD3 they say they have not come across this before ?
  4. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    A few ideas spring to mind, mostly pressure related.
    1. E-diff leakoff from solenoid
    2. Loose bleed screw on actuator
    3. Lazy pump or pressure switch on valve block
    4. Voltage issue
    5. Actuator wear (less likely)
  5. tazandjan
    39,273
    Wally- There you go, help from a pro. Thanks Eddie.
