F430 F1 stalled at light | FerrariChat
Discussion in '360/430' started by av2, Jan 14, 2011.
  1. av2
    av2 Formula Junior
    May 22, 2008
    478
    S. California
    Took the car out last night after it has been sitting in the garage for almost a week. After driving for about a mile and had to stop for a traffic light. I was the first car at the light and there was a slight incline. As soon as the light turned green, right foot off brake and stepped on the accelerator gently and...it STALLED. I was like what the hell. There were a few cars behind me, and they must be thinking "who is this idiot in the Ferrari." Turned the key off, on and hit the starter and luckily, she re-fired right up. After another few miles of driving, I turned the switch to sport, rain modes and tried to duplicate the problem on a similar inclined slop and then on a steeper slope. The car rolled off smoothly with no hesitations. I had the car in rain (auto) mode when it stalled at the light. Anyone had similar problems? Searched and most known problems were years ago with no updates.
  2. Testacojones
    Testacojones F1 Veteran
    Nov 3, 2003
    5,198
    Florida
    Luix Lecusay
    I've heard things like this on the F1 models, or sometimes the car starting like in four cylinders. There was a thread about something similar to your issue just a few days ago. And if I'm not mistaken someone posted something similar on a Lamborghini forum and it was related to e-gear Gallardos. I want to see what respond you get. I have a manual with over 18K miles and my car has never started funny or stalled.
  3. Robdownunder
    Robdownunder Formula Junior
    Feb 6, 2009
    580
    Australia
    Rob
    Never happened to mine but tell me what is rain mode?
    Rob.
  4. tazandjan
    39,176
    Rob- Officially Low Grip Mode, the one between Ice and Sport.
    Taz
    Terry Phillips
  5. Vasileios
    Vasileios Karting
    Dec 5, 2009
    52
    I had an 05' 430 and similar thing happened to me. It has nothing to do with snow, rain, sport, or race mode. I thing you should bring it to your dealer's attention. Most likely the PIS has to be adjusted which it's not a big deal. However, it can also be the bearing and I hope not in your case because it's a big and expensive job. Good luck and let us know.
  6. steelej
    steelej Formula Junior
    Jan 15, 2007
    433
    My 430 has done this once in the year and a bit i've owned it and 13000 miles driven. They're 'quirky' :) I wouldn't worry about it. And don't drive in the low grip modes they're heavier on the clutch. Sport or race only, just be careful if it's wet.
    John.
  7. MikeR397
    MikeR397 Formula 3
    May 9, 2010
    1,469
    SE Michigan
    I think there was a post here that said if you did not hold the start button long enough it could mess with the ecu and cause running on four cylinders, limp, or other funky quirks that could cause a stall. If it doesn't happen again, then I would not worry or spend money looking into it.
  8. av2
    av2 Formula Junior
    May 22, 2008
    478
    S. California
    Thanks everyone for all of your inputs. Called the dealer and they said it does happen to the F1. If it is doing this more often, then call them back.
    Thanks John. Cross my fingers that it goes away. I'll keep it in sport mode from now on.
  9. alcc
    alcc Karting
    Sep 2, 2010
    183
    Santa Barbara, CA.
    Yes, F1 definitely got quirks. I wouldn't worry unless you experience other symptoms. Mine would clutch/declutch a couple of times getting going on a decline. Otherwise fine. PIS is spot on.
  10. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    F1 quirks would drive me nuts.
    Glad it was nothing.
  11. needspeed
    needspeed Formula Junior
    Oct 5, 2006
    579
    Middle of nowhere IA
    Steve
    #11 needspeed, Jan 14, 2011
    That has happended to me a few times in a 6-speed........OOOOPS I Stalled It! :D .......Steve
    BTW: PIS=??????
