F430 F1 system diagnosis | FerrariChat
Discussion in 'Technical Q&A' started by muratokcu, Jan 2, 2022.
  1. muratokcu
    muratokcu Rookie
    Jan 17, 2019
    9
    murat okcuoglu
    Hi, expert question:
    When your F430 TCU scan indicates you have an excessive oil leak, (150cc/min)
    what is the method to determine which solenoid is the that is leaking?
    thanks!
  2. mahlerfree
    mahlerfree Karting
    Dec 19, 2019
    240
    its not a method
    its written there "clutch solenoid"
    so its the solenoid that is "upper left most " in relation to the car.
    upper means the sky
    left means if you are sitting inside of the car, your left is the car's left.
  3. mahlerfree
    mahlerfree Karting
    Dec 19, 2019
    240
    sorry I was wrong. it should be "upper right most"
    muratokcu likes this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,890
    Central NJ
    Dominick
    Yes as stated above ..the tool and data only points to the clutch solenoid which is usually the first to go since it is used multiples of the others
  5. muratokcu
    muratokcu Rookie
    Jan 17, 2019
    9
    murat okcuoglu
    Qavion likes this.
  6. mahlerfree
    mahlerfree Karting
    Dec 19, 2019
    240
