F430 F1 transmission problem with temperature | FerrariChat
Discussion in 'Technical Q&A' started by Peluca, Nov 15, 2021.
  1. Peluca
    Peluca Rookie
    Jan 13, 2018
    34
    Chile
    Michel Durand
    Hi everyone, I hope someone can help me out I have had a problem with my transmision for a while now.
    When the car is cold everything work ok, gears from N to 1 are fast, it goes from 1 to R directly and all gears work perfectly.
    After the car is hot in a 20 or more minute drive going fast. The first abnormal situation is that when going from N to 1 it takes longer and the car wont go from 1 to R directly I have to select N first.
    Also sometimes it Weill fail to engage a gear and go to neutral and be stick there for about 10 minutes. After it cools down everything is back to normal again.
    I have changed a lot of things now with no success.
    1- Actuator leak fixed.
    2- New pump and accumulator.
    3- New actuator potentiometers.
    4- Bleed screws checked.
    5- New clutch installed and PIS setup correctly according to factory specs.
    6- gear calibration was donde cold and hot.
    7- Relay changed.
    The car is at the Ferraris dealer but we are out of ideas on how to fix this problem. The only certain thing is that the car fails only when it is hot.
    Anyone has had a similar issue? I would really appreciate any ideas.
    Thanks for any help…
    Michel
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,931
    Central NJ
    Dominick
    #2 flash32, Nov 15, 2021
    Have them check the solenoids the leak rates on the power unit
    Also you possibly have a bad new sensors ..cause the problem does point to those even though you changed them
  3. windsock
    windsock Formula 3
    1,153
    Common issue. IS this a 2007 and earlier or a 2008 and later as they are very different? If this is the dealer have they performed the Ediff leak test? Losing reverse hot is a very common symptom for a shift actuator not centered or a PIS set too tight. Saying PIS is set to factory specs is a huge window and it is common for the PIS to get set to tight. Once the car is warm the clutch expands and drags which causes the input shaft to still turn when attempting to get into reverse. The dealer should have performed a gear grid calculation and documented the centering of the shift actuator, centered it and perform it again to confirm proper centering. there are a lot of dealers that no longer have techs that are fluent in 430 and earlier cars.
    flash32, Qavion and Island Guy like this.
  4. stasha
    stasha Karting
    Sep 10, 2021
    128
    steve steve
    No wait. I'm ignorant and i don't want to waste time researching...but, "solenoids"? Is this an automatic?
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,931
    Central NJ
    Dominick
    The F1 systems has solenoids to engages thru hydraulic pressure the clutch and moves the actuator which changes the gears like your right hand would on a regular manual
  6. Peluca
    Peluca Rookie
    Jan 13, 2018
    34
    Chile
    Michel Durand
    We dismounted the actuator and found some gear move together with others. Please check the video. Is this normal behavior or this could be the problem?
    Any ideas and how to fix this would be great.
    Michel
  7. windsock
    windsock Formula 3
    1,153
    No
    Normal
  8. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,952
    The Cold North
    Tom
    Do this test..easy to do..no scan tool required.
    With the car cold..open the door. Listen for the f1 pump. Wait unit it stops running.
    Get in the car..shut the door and key up..do not start the car. With key in position 2 (just before crank position).. wait for F1 pump to stop cycling once again.
    Put foot on brake..and shift 1,2,R. You should be able to select those gears without the F1 pump turning back on. If the pump cycles during this test..your accumulator is shot and needs replacment.
    If it passes this test cold...repeat when engine is hot and see how it reacts.
    2bf360, brian.s and Qavion like this.
  9. Peluca
    Peluca Rookie
    Jan 13, 2018
    34
    Chile
    Michel Durand
    Why not, I do not think that the top ones should move toghether. I would appreciate what you think.
    Thanks Michel
  10. Peluca
    Peluca Rookie
    Jan 13, 2018
    34
    Chile
    Michel Durand
    I have done this test and I am able to move the gear with no problem I can change the gears a few times and then the pump come on which is normal. Both, the pump and accumulator are brand new. So do not think the problem is there.
    Remember the problem only happens when the car is very hot.
    Michel
  11. windsock
    windsock Formula 3
    1,153
    This problem happened a lot on early 430 and occurred on every single 430 challenge car we had early on. Reverse was fine until you came off track and then it would no longer engage reverse. It was always due to a centering issue.
  12. Peluca
    Peluca Rookie
    Jan 13, 2018
    34
    Chile
    Michel Durand
    But in this case R come in you just need to go to N first. Also it is strange that it takes longer to go from N to 1.
    Those two gears stuck in the video I uploaded seem strange.
  13. windsock
    windsock Formula 3
    1,153
    Remember the tow shoes on each side of the shifting finger prevent the adjacent shift rods from moving and prevent actuating two gears. Image Unavailable, Please Login
  14. Peluca
    Peluca Rookie
    Jan 13, 2018
    34
    Chile
    Michel Durand
    So to your opinion the problem is no those two getting stuck toghether and it is adjusting the finger to hace the correct center?
  15. windsock
    windsock Formula 3
    1,153
    Yes I would perform the centering operation very carefully. The other thing to check would be looking at input shaft RPM and engine RPM. If you have anything causing drag in the clutch and it causes input shaft speed to be present you will not get Reverse as there is no synchro but you may be able to get 1st which is synchro'd. Putting it is first stops the input shaft and then you can get reverse.
    tbakowsky and Qavion like this.
  16. Peluca
    Peluca Rookie
    Jan 13, 2018
    34
    Chile
    Michel Durand
    Thanks!!! One important thing we got anothe F430 who is working great. Changed the actuator and the problem with a still there. So I do not think the problem is the actuator. Also we checked and there is no drag.
  17. spydermanf360
    spydermanf360 Rookie
    Aug 5, 2006
    2
    Were you able to resolve this problem? I have a 2007 F430 Spider with the exact same symptoms.
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,931
    Central NJ
    Dominick
    My recommendation is for you to open a new thread , introduce yourself a little ( how mechanically inclined you are) , more about the car ( miles, when purchased, when problem started ) and I am sure we can help you
    nessus-gte and Flyingbrick242 like this.
