F430 F1 won't start or go into gear | FerrariChat
Discussion in '360/430' started by wahoo5, Jul 15, 2017.
  1. wahoo5
    wahoo5 Karting
    Nov 9, 2009
    182
    Richmond, VA
    David
    I took a video of trying to start my car.
    https://youtu.be/Mu3Ni_Ti60k
    F430 starter pulses on/off and car won't go into gear. The car starting sound is normal other than the pulse on/off, i.e., much louder than it sounds in the video. F1 pump sounds like it primes normally when door is opened. System check at start shows good. Idiot lights are normal until you push the start button the first time. I don't see any fluids under car or any obvious leaks in engine compartment. I have not taken the undertray off.
    Any ideas what I am dealing with? Ediff solenoid? Car is a 2006 with about 20k miles.
    David
  2. Red 27
    Red 27 Formula 3
    Feb 2, 2008
    1,002
    San Diego, Ca
    Dave
    Mine has done something similar with a low battery. Charged it up and the car started no issues.
  3. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    You have a discharged battery. If the battery is older than 3 years, just replace it.
  4. wahoo5
    wahoo5 Karting
    Nov 9, 2009
    182
    Richmond, VA
    David
    Ok. Thanks, guys. I hope you are right. A new battery may the cheapest possible Ferrari fix!
  5. wahoo5
    wahoo5 Karting
    Nov 9, 2009
    182
    Richmond, VA
    David
    It was the battery. I trickle charged it for 8 hours and it cranked normally. I will replace it this week.
    Thanks again.
