F430 Fault Code PO442 | FerrariChat
Discussion in 'Technical Q&A' started by Stevemogg, Sep 22, 2022.
  1. Stevemogg
    Stevemogg Rookie
    Sep 22, 2022
    1
    Leigh, Lancashire
    steve mogg
    I have an engine management light on with an error code of PO442 - Evaporative Emission System leak detected (small leak)
    Does anyone have any indication to what fault this may point to.
    The car drives completely normal at present.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,084
    Central NJ
    Dominick
    Check gas cap
    Circle K likes this.
  3. tazandjan
    39,318
  4. windsock
    windsock Formula 3
    1,162
    Common and there are three areas we see issues with beyond a loose gas cap on both the 360 and 430. First is cracked lids on the fuel pumps. Second leaking gaskets or cracked rollover valves. Third stuck purge valves, usually with carbon from the charcoal canister. System should be smoke tested under pressure to trace the source of the leak. If its a spider it a crappy job as to access the rollover valves requires removal of the convertible top cartridge.
    Qavion and flash32 like this.
