F430 Fine White Grit In Engine Compartment | FerrariChat
Discussion in '360/430' started by Jrosenthal, Dec 11, 2021.
  1. Jrosenthal
    Jrosenthal Rookie
    Nov 8, 2021
    10
    jonathan rosenthal
    Does anyone know what the fine white grit could be throughout
    engine compartment after driving for an hour? Feels like very fine sand.
  2. Danedingerson
    Danedingerson Karting
    Dec 26, 2011
    236
    Maui
    Dane
    From your catalytic convertor?
  3. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,111
    Josh @jtcarprojects
    Rear muffler coming apart
    DBomb117, Jackson32 and patina like this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,921
    Central NJ
    Dominick
    Could be your headers failing and blowing heat shield material around ..very common in the f430 ..do you know if there were replaced ?
  5. vrsurgeon
    vrsurgeon F1 World Champ
    16,527
    Charleston, SC
    Curt
    Insulation from factory headers or exhaust. They use a white insulation that disintegrates with time. Just brush it away or replace muffler/headers with aftermarket.
  6. Jrosenthal
    Jrosenthal Rookie
    Nov 8, 2021
    10
    jonathan rosenthal
    Thanks for the quick feedback. This is a 2008 F430 with 10k miles. I’m told that 2008 and 2009 didn’t have the header problem. I just had the car fully serviced but will inquire about muffler and catalytic converter.
  7. dom1172
    dom1172 Karting
    Mar 26, 2005
    152
    Sarasota, FL
    Dom
    They all had the issues - 2nd Gen was supposed to be better but not immune
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    The silencer box has white insulation and then a stainless covering, it starts to breakup and comes out as dust. The later cars still have manifold problems caused by the expansion being constrained. The Capristo expansion brackets help a lot.
  9. patina
    patina Formula Junior
    Jul 9, 2005
    504
    Lake Norman, NC
    This. I’m sure you have a crack somewhere on the muffler. Likely at the seam.
  10. Mario Andretti
    Mario Andretti Formula 3
    1,776
    Boston
    The cats are also insulated with the white stuff, and a sheet metal on top; you can see it at the temp sensor flange. check cats too.
  11. Gillis Haasnoot
    Gillis Haasnoot Karting
    Feb 4, 2020
    104
    Leiden, Netherlands
    Gillis Haasnoot
    I did some thorough investigation using cameras. My problem was seeing white smoke/dust under hard accelerating inside the engine bay. It turned out to be the white powder coming out of the muffler pipe connections. Not harmful at all, just annoying. After a good hard track session it's usually gone for a few 1000miles. But comes back at some point.
  12. AandSC
    AandSC Formula Junior
    957
    Jax, FL
    Allen
    Myself and a couple others had the muffler outlet pipes welded shut. Keeps the white powder in and was only $100.
  13. Jrosenthal
    Jrosenthal Rookie
    Nov 8, 2021
    10
    jonathan rosenthal
    Thanks. Would a header issue manifest as fine white grit? Sounds more like the silencer insulation. How do you check? Is a new OEM silencer recommended or aftermarket or nothing?
  14. Mimmo Blue
    Mimmo Blue Formula Junior
    Apr 17, 2018
    324
    Stoney Creek, Ontario, Canada
    Dom
    I your headers have a cracked then the exhaust coming out of the crack could break down the insulation closest to the crack and eventually come out from under the shield. Look at your undertray from above, is the white powder settling below the headers or under the muffler?
  15. Jrosenthal
    Jrosenthal Rookie
    Nov 8, 2021
    10
    jonathan rosenthal
    The white brick very fine sand is all over the engine compartment even on the left and right aprons and some on the back window ledge. It blows off easily with a air hose. But doesn’t appear to be collecting in any one spot.
  16. one4torque
    one4torque F1 Veteran
    5,721
    Houston
    One4torque
    My factory 360 muffler box was putting out white dust after I purchased my car from a collector. It had sat up for a couple years.
    After 1 yr of driving weekly it stopped puking powder.
    just an fyi… it might go away like mine did.
  17. DL4567
    DL4567 Karting
    Nov 25, 2004
    223
    Atlanta
    Jrosenthal, when I was searching about this a few months ago, this thread below was super helpful. At the time, the youtube link in the first post showed the white powder coming out when revving the engine (like in the picture), but alas it's been changed to "private" now. The Aldous Voice link in that thread is great too.
    https://www.ferrarichat.com/forum/threads/2006-f430-white-dust-bad-headers-or-bad-weld.516180/
