F430 flickering hatch LEDs when braking | FerrariChat
Discussion in '360/430' started by ironchef1369, Dec 28, 2012.
  1. ironchef1369
    ironchef1369 Rookie
    Feb 28, 2012
    29
    Irvine, CA
    Brandon H
    Any idea what might be the cause? The 3rd brake light on the rear deck flickers when I hit the brake pedal. Driver and fellow Ferrari enthusiast pointed it out to me when at the stop light yesterday.
    Holding the brake pedal continues the flickering. It seems to be at the edges of the led center brake light.
  2. DanS*
    DanS* Karting
    May 29, 2012
    218
    Manhattan Beach, CA
    Dan
    The most obvious thing is a loose connection. If all LEDs flicker it is probably a wire or connector to the strip. If just the outer ones (I was unsure from your description) then it sounds like a loose connection inside the strip. Unless it's intermittent, it should be easy to diagnose and repair.
