f430 Gear box ... | FerrariChat
f430 Gear box ...
Discussion in '360/430' started by bmw550i, Sep 10, 2010.
  1. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    ok I know this toppic is beaten up bloody ...but what is the best gear oil for an f430 F1 ??
    After doing multiple searches I get info on previous models , 308,328, 355,360s ....
    does the 430 have the same style diff ???
    redline , royal, valvoline ??? ..should I be messing with lsd dditives here ?
  2. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
  3. blackbolt22
    blackbolt22 F1 Veteran
    5,798
    Boca Raton, FL
    Mr. Anderson
    Apparently it is unknown or a big secret. BTW I have no such knowledge.
  4. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    550
    Fountain Hills
    Jon
    #4 zstyle, Sep 12, 2010
    what we put in at the shop is the shell 75w90
    the 360 and 430 use the exact same gear box where as the the other models are different compared to the 430/360. when refilling the gearbox i forget exactly the capacity but check the fluid level by unscrewing the dipstick and having it rest on the hole (not screwed in). also recheck the level after the fluid has warmed up.
  5. tazandjan
    39,063
    Jon- The 355, 456, 550, 575, 612, and 599 all call for the same or similar Shell 75W-90 GL-5 oil in the transaxles as the 360/430.
    Taz
    Terry Phillips
  6. APC 571
    APC 571 Rookie
    Oct 6, 2009
    17
    Newport Beach CA
    Aidan
    shell 75-90 would my first choice but any good 75-90 synthetic transaxle oil should be good as long as it has a friction modifier for the diff in it.if there is no friction modifier the diff will chatter.
  7. speedy1wrc
    speedy1wrc Rookie
    Sep 29, 2010
    49
    Buffalo, NY
    Mark Wetzel
    We use NEO 75W-90 or 75W-90R. Both exceed the Shell spec. We use it in everything BTW.
  8. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    redline 75w90ns w 3oz fm
