F430 Gearbox Drain Plug Torque | FerrariChat
Discussion in '360/430' started by ilappassionatodicavallino, Jul 11, 2022.
  1. ilappassionatodicavallino
    Nov 2, 2016
    54
    Texas
    I have a question for any experienced Ferrari technicians on the forum. I just finished changing the gearbox oil in my 2006 F430 coupe. Everything went well until it came time to torque the drain plug. I have a high quality, professionally calibrated torque wrench. I also have four copies of the F430 Workshop Manual obtained from different sources. Each copy calls out a torque value for the gearbox oil drain plug (Ferrari PN 183962) of 75 Nm (~55.3 ft/lbs). The gearbox casing is soft aluminum and the plug appears to be brass or bronze. 75 Nm seems excessive to me and I'm really uncomfortable applying that much torque to that plug. I have torqued the plug to 38 Nm (~28 ft/lbs).
    Am I making a big mistake? Any help would be truly welcomed.
  2. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,421
    Santa Clarita, CA
    I do all my own maintenance on my 2009 F430. There’s no way it needs to be torqued to 55 ft lbs. I’m not sure what I tightened mine to, but probably around 25 ft lbs and it’s been fine.
    Qavion and EastMemphis like this.
  3. Flyingbrick242
    Flyingbrick242 Formula Junior
    677
    Northern AZ.
    Been there with the same concerns just like the OP states the spec seems excessive for the mating material.
    Curious what the Ferrari techs have to say.
  4. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    As a BMW mechanic stated once, just make it "German Tight"
    You certainly don't need to get to 55 ft-lbs
  5. colorfull
    colorfull Formula 3
    2,333
    Franklin Park, New Jersey
    John Napoli
    As the op stated it says 75, not 55 in the manual
    I could not get mine to that level either, I seriously suspect it's documented incorrectly, they might have just carried over the oil plug value
    Anyway, don't recall what I got mine to, 50+ I think, seemed sufficiently tight and no issues after 500 miles or so.
    Also interested in a Ferrari tech report
  6. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    hand tyight snug is more than enough pressure
    WillAsh likes this.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,899
    Central NJ
    Dominick
    When you feel the copper washer get squashed - somewhere between 30 - 40 lbs
  8. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,017
    NE FL
    Ken
    Be careful with Ferrari torque values.
    I found many of them are purely arbitrary, it's almost like they tighten the good and tight and then somebody went back there and said hey we got to post some values for our manuals... and they just randomly picked numbers that can or cannot generally coincide with the size of the bolt etc.
    It's important to realize that there are some critical components that require very specific torque values. But for the majority of everything else, a mechanics touch AKA good and tight is actually ideal
  9. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    "a mechanics touch AKA good and tight is actually ideal"
    This is the exact point
    Use common sense
  10. Mario Andretti
    Mario Andretti Formula 3
    1,774
    Boston
    I had the same issue... when I changed my oil I had to use an extension bar when I removed it.... someone did torque it to that value. Geez. I was scared I will strip the threads or crack the pan ...
  11. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    tight is good, tighter is not better
  12. RedTaxi
    RedTaxi F1 Rookie
    3,338
    New Zealand
    Glen
    Never torqued a drain plug in 40 years of servicing my cars, family cars and friends cars. Just tight but not crazy tight. You can get a feel for when the copper washer begins to yeild. It's an odd feeling though, feels just like when the threads start to strip.
    Don't do this...
    Extreme1 likes this.
  13. ilappassionatodicavallino
    Nov 2, 2016
    54
    Texas
    #5, the manual calls 75 Newton-meters, which is approximately 55 foot-pounds, excessive in my opinion. Just from the feel of the thing, around 20 to 30 foot-pounds (approximately 27 to 40 Newton-meters) is about right.
  14. ilappassionatodicavallino
    Nov 2, 2016
    54
    Texas
    Many thanks to everyone who responded. RedTaxi, that is one scary picture. Aye, caramba!
