F430 hood latch issue | FerrariChat
Discussion in '360/430' started by Evan430, Mar 30, 2022.
  1. Evan430
    Evan430 Rookie
    Mar 12, 2021
    43
    Toronto
    Evan D
    Hey guys, so today I went to watch up my girl from hibernation. I was doing some work on her, opened the trunk to toggle the battery off to kill the car. When I turned it back on I noticed that the hood latch would not lock. It will close and stay in safety position without opening, but will not fully shut. I tested the latch and it doesn't appear to want to lock closed. It is well lubed and was prior to storage. I attempted to lock/unlock the car in attempts to maybe wake the lock up but no luck. Could the battery reset have caused the issue? Any other trouble shooting I should do? If not, do I replace the latch? Thanks guys!
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,927
    Central NJ
    Dominick
    Check the manual cable ..maybe it is getting hung up .. rust inside if it
    Red 27 and LorenzoR like this.
  3. KatMan
    KatMan Formula Junior
    498
    Silicon Valley
    Stan K
    This happened to me. It turns out that I had inadvertently pulled the safety trunk release cable in the trunk. This is a safety feature required in US cars. Don't know if Canada has a similar requirement. I just pulled on the cable and the problem went away.
  4. Evan430
    Evan430 Rookie
    Mar 12, 2021
    43
    Toronto
    Evan D
    I removed the carpet and took a look. Everything was corroded and rusted - caused it to sieze. I order a new latch and cables. The install should be a treat!
    Qavion likes this.
