News
430 F430 hood, roof and bonnet dimensions (length)
Discussion in '360/430' started by Andrew Stewart, Oct 21, 2019.
  1. Andrew Stewart
    Jan 8, 2019
    5
  3. BAD430BENZ
    BAD430BENZ Formula Junior
    May 13, 2014
    716
    EL PASO , TX
    JASON
    Why does pre-planning of having to cut them have any effect on you buying them ? Just buy them , cut them and enjoy the new look :D
  4. Andrew Stewart
    Jan 8, 2019
    5
    Thanks Bad430, agreed I am going to do some cutting! But as the pieces come in separate pre-cut segments, I want to make sure the roof and bonnet segments are long enough out-of-the-box.
  5. BAD430BENZ
    May 13, 2014
    716
    EL PASO , TX
    JASON
    So you are trying to find out if they are long enough ? That makes more since because the wording on your original post says you are trying to find out how much you have to cut off of the original stickers .
  6. Andrew Stewart
    Jan 8, 2019
    5
    Exactly. I mentioned cutting originally because if one piece had extra length and one was too short, I could cut the longer one and match it up next to the shorter piece to make it longer.
