430 - F430 Ignition Coils | FerrariChat
430 F430 Ignition Coils
Discussion in '360/430' started by RichardCH, Aug 21, 2019.
  1. RichardCH
    RichardCH F1 Rookie
    4,661
    At which service are these normally replaced please and any advice on which brand and where to buy please ?
  2. 24000rpm
    24000rpm F1 Rookie
    buy OEM or bosch OEM, usually replaced when you got a problem with ignition or combustion, or look up in the ferrari service book
  3. RichardCH
    RichardCH F1 Rookie
    4,661
    this part ref MW Stewart 430 Scuderia and 16M Ignition Coils (Ion Sensing Applications)
    * Original: 231359 - Scuderia, 16M
    * Update 1: 248406 - Scuderia, 16M, 599 GTO, 458 Challenge, 458 Spider, FF, 599 SA Aperta, F12 Berlinetta, 458 Speciale, La Ferrari, GTC4 Lusso
    * Update 2: 290850 - Scuderia, 16M, 599 GTO, 458 Challenge, 458 Spider, FF, 599 SA Aperta, F12 Berlinetta, 458 Speciale, La Ferrari, GTC4 Lusso, 458 Speciale Aperta, La Ferrari Aperta, F12 TDF
    * Update 3: 337713 - 812 Superfast, GTC4Lusso, and backwards compatible with all of the above.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    If they are working, why change them ?
  5. RichardCH
    RichardCH F1 Rookie
    4,661
    well I experienced on my Porsche Turbo that performance wanes over time by car is 11 years old and its not like a metal piston or valve that absorbs heat much more effectively
  6. RichardCH
    RichardCH F1 Rookie
    4,661
    Is there a Bosch alternative part number which is half the price for the same part ?
  7. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Richard,
    Your car is an F430?
    Your can find them in eBay for $80.00 Bosch OEM from a seller from Latvia.
    There are 2 part numbers due to cable lengths.
    188504 for cylinders 1, 2, 7, 8
    186914 for cylinders 3, 4, 5, 6
    Dan
    Sent from my SM-G950U using Tapatalk
    f355spider likes this.
  8. RichardCH
    RichardCH F1 Rookie
    4,661
  9. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I have a post here on ignition coils for F430 with equivalent Bosch part numbers. Kindly do a search.
    I just purchased one in eBay from a seller from UK for $75.00.
    I believe dealer is asking $425.00 each.
  10. RichardCH
    RichardCH F1 Rookie
    4,661
    Europares is similar The correct Ignition Coil for the F430 Spider is #281449 at £58.62 each – available from stock. (Please provide VIN number before ordering to ensure supply is correct.)
    whatheheck likes this.
  11. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,754
    England
    Mark
    Pre 2007 is one part, post 2007 is another (push in type), and Scuderia/16M is another (push in, ion sensing).
    They don't really warrant replacement as a precaution - they are reliable.
  12. RichardCH
    RichardCH F1 Rookie
    4,661
    thks for the help
    mwstewart likes this.
