F430: Immobilizer problem. Please help! | Page 3 | FerrariChat
Discussion in '360/430' started by Eric C, Aug 14, 2017.
  1. LorenzoR
    LorenzoR F1 Rookie
    Fingers crossed for ya,,,big bummer hopefully not to major
  2. scuderia09
    scuderia09 Formula 3
    1,045
    you need the Leonardo or a SD2 or SD3 i know my Leonardo could reset your Immobilizer if you have the latest update.
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    SD2 has no support for 430's - would need to be SD3 or SDX
  4. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,959
    St. Louis, MO
    Eric
    Just talked to Ferrari. They said my Immobilizer ECU is bad and I need a new one. What are my options here? Buy a new one from Ferrari?
  5. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    You can try Ricambi and see if they carry it. If they do it will most likely be much less than what the dealership will charge you.
  6. ideloera
    ideloera Formula Junior
    Jun 2, 2015
    525
    Chicago
    Isi
    Continental Ferrari (in Chicago) requires that you buy the parts from them or they won't do the work. They wanted me to pay $1250 for Potentiometers and about $2k in labor. I told them that I would be supplying the Potentiometers (got them from Ricambi for about $500) and they refused to do the work. I purchased my car from them.....****ty way to treat a client.
  7. ideloera
    Jun 2, 2015
    525
    Chicago
    Isi
  8. Eric C
    Mar 20, 2009
    10,959
    St. Louis, MO
    Eric
    I tried, Ricambi says it's a dealer only item. I'm looking it up. Is it just the little blue box under the steering column? If so, I'm seeing used prices of just $100 or so. I thought the immobilizer ecu was behind the seat and more much expensive?
  9. Jgivoo
    Jgivoo Formula Junior
    436
    New Jersey
    Exotic auto recycling $100. Ebay
  10. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,753
    England
    Mark
    The Bosch immobiliser module is behind the steering column. It is paired with your keys and the right side engine ECU. There is a cheap way to replace it (not ideal) or the correct, more expensive way:
    Cheap way:
    1) Buy a used immo module and matching keys;
    2) Swap the immo transponder from new keys to your existing keys, so your existing keys still work the locks and alarm but are matched to the new immo module;
    3) Swap your left and right engine ECUs. NOTE: This will only work if the ECUs have not been swapped before, otherwise the left ECU will no longer be a virgin and will be paired to your old immo module.
    Correct way:
    1) Buy a new immo module;
    2) Ferrari code your existing keys to new immo module;
    3) Right side engine ECU is put in learning mode to accept the new immo module.
  11. Eric C
    Mar 20, 2009
    10,959
    St. Louis, MO
    Eric
    Just spoke to Ferrari. They swapped out the immobilizer antenna. Didn't fix it.
    Their scan tool won't even link up to my immobilizer.
    So, the price for the immobilizer kit which includes the immobilizer, new code card and 2 new chips for my keys is $1,100. So, $1,800 total with the labor they've put into it so far, installation and programming. Plus $900 in shipping. Ugh.
    He said he's 90% sure this is the problem. A problem that they've never seen on a F430 before.
  12. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,753
    England
    Mark
    In my experience those immo modules can take an age to connect to, and multiple attempts. They use a really slow baud rate on the K line (diagnostic bus).
  13. Eric C
    Mar 20, 2009
    10,959
    St. Louis, MO
    Eric
    They just called to let me know that it's fixed. The Immobilizer ECU went bad.
    whatheheck likes this.
  14. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    829
    Michigan
    Tony
    Eric - Glad you got this fixed. It took some time but hopefully it is done right and you shouldn't have to worry about it again!
  15. Eric C
    Mar 20, 2009
    10,959
    St. Louis, MO
    Eric
    Yeah, it's a little unsettling that I'm the only one that has had this problem.
  16. Eric C
    Mar 20, 2009
    10,959
    St. Louis, MO
    Eric
    They did say that I have a exhaust leak when it's cold but goes away when it gets warm. No telling what that is since I replaced the headers about 500 miles ago.
  17. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,436
    On the Limit
    Dino
    The immobilizer board had a bad Tyco relay. I sourced the relay in Portugal ($6/free shipping). I had them replaced and the car worked perfectly for 5 months, but the problem is creeping back. I may replace the immobilizer system and hopefully that will be the end of this saga. Image Unavailable, Please Login
  18. Eric C
    Mar 20, 2009
    10,959
    St. Louis, MO
    Eric
    Here's a screenshot of the invoice. Was originally told the part was $1,100 but it was only $400. So $1,400 bucks in labor. Ugh.
  19. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks for sharing info and updates Eric and glad to hear is now all fixed.
  20. Eric C
    Mar 20, 2009
    10,959
    St. Louis, MO
    Eric
    It's all fixed and sitting in my garage. Yay! Also found out I have 92% clutch life remaining. Yay!
    chenglo1 and whatheheck like this.
  21. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Outstanding news! Thanks for sharing Eric and glad to hear issue solved!
    Dan
  22. LorenzoR
    LorenzoR F1 Rookie
    yes good to hear, what a relief its done....
  23. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Regarding the remaining clutch life....be careful. This can be fooled if someone in the past played with the parameters.
  24. Eric C
    Mar 20, 2009
    10,959
    St. Louis, MO
    Eric
    Has this ever actually happened?
  25. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I've been told yes. On my 355 F1, the system is saying something like 90ish% worn with 15K miles and the car drives perfect. Discussing my other values with a Pro Tech it seems my "Clutch Position As New" is 13.49 mm and it's supposed to be 17ish mm. That value is used to determine clutch wear so if it's wrong, so will the calculation.
    I've been told 355's and early 360's will go over 100% wear (like 110%, etc) but later cars will reset to zero after 100% (I don't have 1st hand experience with this statement however).
    But, Pro techs will look at the other values to see if they make sense and not just go off the Clutch wear value. Ask for the full screen shot / print out.
    Here is mine that I pulled from my 355 with my SD2
