F430 Inner Door Jam Wear? | FerrariChat
Discussion in '360/430' started by Franchise1450, Sep 17, 2023.
  1. Franchise1450
    Franchise1450 Karting
    Apr 20, 2019
    88
    Portland, OR
    Franchise1450
    Looking online and cannot find this part, where to replace or what it’s even called. It’s not the door sil as that’s the part you can see when door is open. This is like the lower inner door jam that is right next to your calf when sitting in the car. Looks to be made from vinyl or something similar?. Just bought a new to me 430 and they look very worn so want to replace.
    First photo with red arrows is my car which is a 2007 with about only 3,000 miles.
    Second photo is a google pic of another 430 where this same piece looks to be carpet?
    Doesn’t appear to be consistency between years on how they designed this part of the lower interior door area. Trying to get a name, part number and options for replacement or refurbishment ideas. Thank you.
    EastMemphis likes this.
  2. CoreyNJ
    CoreyNJ Formula 3
    2,470
    New Jersey Shore
    It's not an inconsistency issue, but depends on which option you have. Sounds like you have leather sills. The standard car has carpet and aluminum, and then there is the option for Carbon Fiber, which has a carbon fiber inner and central piece with a small area in Aluminum to prevent scuffs...
    Here is epic of the carbon sills from my car.
    If yours are leather, you can just have them recovered. They would not be vinyl, this is a Ferrari not a Toyota.
  3. LorenzoR
    LorenzoR F1 Rookie
    Corey r your door sills oem?
  4. CoreyNJ
    CoreyNJ Formula 3
    2,470
    New Jersey Shore
    Yes...
    Right now the only non-OEM interior pieces in my car are the cup holder replacing the ashtray and the floor mats because I wanted to save the factory floor mats from wearing and to be honest they were a little plain...
    I am thinking of changing the door lock to carbon fiber only for durability purposes since it is harder to scratch.
  5. LorenzoR
    LorenzoR F1 Rookie
    Mine r leather. but carbon is on my list. Just not ready yet as their pretty pricey
  6. colorfull
    colorfull Formula 3
    2,340
    Franklin Park, New Jersey
    John Napoli
    I have the exact same configuration as the OP. I think those front sill plates are aluminum. I didn't use a polisher on mine, but used metal cleaner with some decent amount of rubbing and they came out much better.
    I think to replace them, you would have to replace the whole sill with the leather but I'm not sure. They don't seem to be separate parts.
  7. veilstylez
    veilstylez Formula 3
    1,020
    SoCal
    Those are called Crossmember covering or internal sill plate. They make them in leather or full carbon. You'll see the full carbon version in a lot scuds/16m. I have them in Carbon its one of my favorite part of the car. It took me a year to find a set...I actually found them separately....Freddan has a set for sale. Its a rare carbon piece and the factory doesn't make them anymore.
  8. veilstylez
    1,020
    SoCal
  9. CoreyNJ
    CoreyNJ Formula 3
    2,470
    New Jersey Shore
    I agree, this was a feature that sold me on my car.... (ignore the wet seat bolster side, should have wiped it down before the pic... I'm so lazy)
  10. Yesitsfast
    Yesitsfast Karting
    Nov 11, 2014
    81
    Has anyone found out if the leather and aluminum are separate pieces ? If so is there a part number for the aluminum ?
    Thx much appreciated
  11. GogglesPisano
    GogglesPisano F1 Rookie
    3,215
    East Bay, California
    Joe
    They are not. It’s a fiberglass base with an aluminum plate glued to the top in the one area. The leather is glued over the assembly. It can be reupholstered but not easily removed and replaced.
  12. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    Interesting, so that leather stays in place, but not on the dashboard
    Sj_engr likes this.
  13. GogglesPisano
    3,215
    Joe
    It could be edge glued only, but yeah. You’d need to peel it off. I have a spare set I bought to install on mine that I need to recover and spiff up the aluminum. I’ll be sure to document it. That’s this fall/winter though.
  14. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    I was actually commenting on where the leather is down below in the dark, glue doesn't seem to be affected
    Makes an argument for the dash issue being probably from sun exposure
  15. GogglesPisano
    3,215
    Joe
    Dash issue is 100% from the sun shrinking it. I don’t think Ferrari glues the entire surface of the leather on any panel. Certainly not the doors. Makes for a more flat appearance but also allows for easier lifting. Either way, shrinking leather has incredible strength. Enough to tear fibers attached to glue so it wouldn’t matter if the glue was all over or still intact.
    colorfull likes this.
