F430 License Plate / Back-Up Camera Suggestions ... | Page 2 | FerrariChat
Discussion in '360/430' started by BigJay2050, Jul 3, 2014.
  1. Ray Smith
    Ray Smith Formula Junior
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    Do you have a link to that device? I want one for my F430. TIA
  2. one4torque
    one4torque F1 Veteran
    5,720
    Houston
    One4torque
    #27 one4torque, May 19, 2020
    I bought a spare lic plate light, drilled a hole, then mounted this camera using a rubber gasket.
    Dep on style of lic plate light you might have to source another 12 volt bulb holder to accommodate the camera mount.
    it looks very close to the oem
    and it is 100% reversible if you sell. No holes in body work.
    Also the clarion head nz503 unit can be found for 150-200 wo the horsey occasionally. There where two for sale 1q20.
    I a b tested the nz503 vs the latest pioneer double din and to my ears the clarion has the pioneer beat. But this was through the head unit amp only.
    https://www.ebay.com/itm/392164875754
    Manda racing likes this.
  3. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    do you have pics of what your finished product looks like, Jeff?
    I'm interested in installing a back up camera but don't particularly like the long strip ones that bolt on top of the license plate
  4. one4torque
    5,720
    Houston
    One4torque
    #29 one4torque, May 21, 2020
    Manda racing, timwu12 and gsworld2014 like this.
  5. one4torque
    5,720
    Houston
    One4torque
    Ferrparts has used lic plate lights for 30$ on eBay
    see pn 186180
    you can practice on a used 30$ pc
    item no
    123774401630
  6. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    This looks great. My question is which head unit would you recommend connecting this to in place of the OEM radio unit?
    I live in Costa Mesa, CA so if you have a shop in mind that performs competent installs I'd appreciate a pointer.
    Thanks,
    Ray
  7. one4torque
    5,720
    Houston
    One4torque
    Light holder eBay desc
    2x T10 T15 168 194 2825 W5W 920 921 Rubber Base Socket w/Pigtail Wiring Harness
  8. one4torque
    5,720
    Houston
    One4torque
    Thus universal camera will connect to any aftermarket head unit. RCA plug.
  9. one4torque
    5,720
    Houston
    One4torque
    You can source a used lic plate 360 light from eBay ferrparts $30. Pn 186180
  10. one4torque
    5,720
    Houston
    One4torque
    #35 one4torque, May 21, 2020
    The f variant
    https://rover.ebay.com/rover/0/0/99?loc=https://www.ebay.com/p/1633781298?iid=362616112690
    this 700 used part has a wire loom that sends vid signal to the head unit
    also takes a 12 v rev light input from the tail light harness
    You can tap into your rev light loom or if you are ocd you can source the short tail light jumper harness from eBay and tap into it and keep your untouched stock harness for resale.
    Solder and clothe tape are your friends.
    it’s a fun diy hack that saves some clams.
    I don’t know if being offset from center by a few inches matters for backup view.. I will only use this for proximity of bumper to curbs and cars... not intending to use those phantom guide lines... I find those hit and miss on am parts.
  11. one4torque
    5,720
    Houston
    One4torque
    Image a little washed out w the sunlight but you get the idea... was testing it all out before button up rear bumper.
    —— not sure why I look bald here.... and. Appears I have swim goggles... but I digress
  12. CoreyNJ
    CoreyNJ Formula 3
    2,446
    New Jersey Shore
    If anyone is interested and wants to keep their factory stereo, I modified a LookIt camera (https://lookitcam.com) by flipping it upside down so I could use the bottom screws only (flipping the camera and modifying the bracket so it can point in the right direction when upside down and then sealing it with black RTV). The lookit cam uses a 3 year battery and my iPhone as a screen. Not as good as having a wired solution which turns on immediately (can take up to 10 or 15 seconds to start), but I didn't want to modify my car at all.
    one4torque and Bob in Texas like this.
  13. gsworld2014
    gsworld2014 Formula 3
    Dec 23, 2014
    1,105
    South Florida
    Greg S
    Just had this one installed.
    https://www.amazon.com/AUTO-VOX-seguridad-caracter%C3%ADsticas-impermeable-IP68-Sensor/dp/B01DNMDVY8/ref=sr_1_30_sspa?crid=4RSPZIC30Q56&dchild=1&keywords=license+plate+camera&qid=1590114350&s=electronics&sprefix=License+plate+ca%2Caps%2C174&sr=1-30-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUE4WUdYWVdCMkdEMTgmZW5jcnlwdGVkSWQ9QTAyMzg4MTczTkcxV0dFRjU0MlNUJmVuY3J5cHRlZEFkSWQ9QTAxODM4MTMxQ0YwUzZBVUVUNkRFJndpZGdldE5hbWU9c3BfYnRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==#HLCXComparisonWidget_feature_div
    Looks great and no permanent modification and looks clean.
  14. RS RS
    RS RS Rookie
    Aug 14, 2019
    38
    usa
    @one4torque - Could you let me know which camera you bought? Trying to do what you did but the ebay link below does not work.
    Thanks!
  15. one4torque
    5,720
    Houston
    One4torque
  16. RS RS
    RS RS Rookie
    Aug 14, 2019
    38
    usa
    one4torque likes this.
