Hello guys! I need help base on yoir experience. I'm from philippines. I have f430 coupe issue with 2km++ odometer only. I started then a multiple fault on cluster (ABS, CST, EDIFF, SUSPENSION, MANETINO FAULT) all appear on cluster. Technician check all fuses and even relay and all are okay (luggage, rear driver and passenger side and max fuse near battery). I forgot what all fault codes but on NFR(ABS) c1266 - pump motor keeps on coming bck. Delete the fault, try to run the car, about 100-200meters fault will come back again, with same fault. Check all speed sensor (all four) using diagnostic tools all are fine. (Raise vehicle and try to rotate one by one all 4 wheels and it reads perfectly on diagnostic tools). Did you all experience it?
Sorry for not responding quick guys, as im out of town. Yes we tried to replace the battery also with optima red top..but same problem. Sent from my SM-A710Y using FerrariChat.com mobile app
I assume you waited a bit between turning the key and pushing the start button. Sent from my iPad using FerrariChat.com mobile app
Yes i always wait for about 20 to 30 sec before start.. Well anyways tomorrow they will replace the abs pump..let see what will happen..or any ideas with same problem with mine? Sent from my SM-A710Y using FerrariChat.com mobile app
Just for an update guys...confirmed ABS pump is the cause..after replacing the ABS pump(no programing, no calibration)- just plug and play, it works fine now..make sure you replace your brake fluid every 2years wether you use your car or not.. Image Unavailable, Please Login Sent from my SM-A710Y using FerrariChat.com mobile app
