F430 new battery | FerrariChat
F430 new battery
Discussion in '360/430' started by chenglo1, Aug 12, 2021.
  1. chenglo1
    chenglo1 Formula Junior
    Jun 23, 2012
    343
    Midwest
    Cheng
    My F430 battery is no longer reliable. Whats a good replacement nowadays? My latest one is a 4 year old Optima. Im curious with all the battery advances that maybe theres lighter more powerful options now.
  2. VAF84
    VAF84 Formula 3
    2,280
    Central Texas
    If you want reliable, Interstate seems to be the consensus. I bought an Optima red top first and it gave some issues; lasted maybe a year before I replaced it with interstate. That's with me keeping the car on a tender anytime I'm not driving it. I'm not very knowledgeable on the performance battery's that are light weight, someone else will have to chime in for that.
    whatheheck and chenglo1 like this.
  3. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,119
    Josh @jtcarprojects
    Antigravity Lithium battery and will drop about 30lbs
    quickjack and vraa like this.
  4. Ray Smith
    Ray Smith Formula Junior
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    Anti Gravity H6/Group 48 40Ah saves about 31 lbs. About $800.00 with a coupon.
    It does require a special charger, a Ctek designed for Li-Ion batteries. ($84.00)
    I removed an almost new Lead acid battery and replaced it with this.
    Ray
    quickjack, chenglo1 and vraa like this.
  5. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    AntiGravity is the hot item right now, lithium is the rage, make sure you get a modern CTEK or NOCO - the right ones can also do lithium
    Otherwise Ferrari dealers use Interstate AGM
    quickjack likes this.
  6. chenglo1
    Jun 23, 2012
    343
    Midwest
    Cheng
    Is the F430 alternator or...electrical system able to recharge the lithium Antigravity as the car is being driven? Im assuming i just need the ctek Li charger as a tender.
  7. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    Yeah, some guys found the alt part numbers were the same on cars that had AGM or Li
    chenglo1 likes this.
  8. chenglo1
    Jun 23, 2012
    343
    Midwest
    Cheng
    Ray,
    Why did u choose the 40 ah? The 24 ah sounds suff with 1000 CCA already. Am i missing something?
