F430 Oil Pressure Indication Issue | FerrariChat
Discussion in '360/430' started by whatheheck, May 14, 2018.
  1. whatheheck
    whatheheck F1 Rookie Owner
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I did a search and every thread I found was on a 360.
    I have an F430 Spider.
    My oil pressure used to be pretty steady at middle mark 70 psi once engine is warmed up.
    Went for a drive last weekend and the needle would hunt, then it pegged max at 140, then a few minutes later dropped to zero, red low level light came on.
    I checked & Oil quantity is fine.
    Looks like Oil Pressure Transmitter is going bad.
    Original part number is 201207. Superseded by P/N: 304074
    According to Ricambi, part number for F430 is 304074, $265.00 each.
    Has anyone replaced theirs. Is it easy to do?
    Do I need to drain the oil?
    Thanks in advance for any info you can share.
    I will also now check workshop manual.
    Dan
    Dan Image Unavailable, Please Login
  2. Gizzi
    Gizzi F1 Veteran Owner
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    Drive it hard for a while. Mine did the same thing. I immediately stopped and checked for oil level and flow. A bit of carbon deposit probably got lodged in the sender unit. I flogged mine for about 15 mins and it’s been good ever since.
    Also, I change fluids every 5k klms, in case you were wondering.
    whatheheck likes this.
  3. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I will try that. Thanks!
    I just had my annual service done 3 months ago so I think I'm good oil and brake fluid wise.
    I just also had my F1 System fluid flushed and system recalibrated just last week. Also had transmission fluid flushed.
    Dan
