F430 PIS Settings and Clutch Configuration | FerrariChat
Discussion in 'Technical Q&A' started by tomov69, Oct 19, 2019.
  1. tomov69
    tomov69 Rookie
    Dec 27, 2013
    44
    Hello Guys,
    I have work today on my F430 Coupe with Leonardo diagnostic because I want to make it more stiff.
    What happened now is that my clutch is slipping.
    Please check the pictures attached is what the diagnostic reads now . Because I have forgot to write down the previous settings of the pis configuration and clutch settings can someone tell me what values should I type?
    Thanks in advance!
  2. tbakowsky
    Sep 18, 2002
    20,044
    The Cold North
    Tom
    Did you replace the clutch?
  3. tomov69
    tomov69 Rookie
    Dec 27, 2013
    44
    No we did not change the clutch. Clutch is the same.
  4. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,233
    Georgia
    Wade Williams
    You may need to just start over and tell the TCU it is a new clutch and let it find the numbers for you. You clutch wear will be reset, so PLEASE write down the wear % it has now and know that the previous wear is still accurate when it resets.
    tbakowsky likes this.
  5. tbakowsky
    Sep 18, 2002
    20,044
    The Cold North
    Tom
    What is your current clutch wear reading?
