F430 power window switch | FerrariChat
Discussion in '360/430' started by 3cats, Jun 18, 2016.
  1. 3cats
    3cats Rookie
    Jan 1, 2016
    15
    Hello, how do you replace the left side power window switch on a 2006 F430? My car has the amplifier under the dash and I can't even begin to see how to get in there.
    Thank you.
    Scott.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    I assume you pull the radio out to get access ?
  3. ideloera
    ideloera Formula Junior
    Jun 2, 2015
    525
    Chicago
    Isi
    Remove the radio and center trim, once that's done you'll see how easy it is to remove the window switches
  4. Tally Ho
    Tally Ho Formula Junior
    Jul 4, 2007
    720
    Niceville, FL
    Bill
    I agree. I think the screws holding the switches in are 7mm. I had to replace both of mine. The hardest part is getting the radio out of the way. The trim piece comes off easy once you remove the F430 plate. Use care when unplugging the connectors.
  5. Jsoderbe
    Jsoderbe Rookie
    Aug 16, 2013
    42
    Sweden/Florida
    Where do you guys buy your new switches? I have only found used ones. My ones are working but scratched up.
    Regards,
    Johan
  6. ideloera
    Jun 2, 2015
    525
    Chicago
    Isi
  7. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hello Johan,
    We can refinish those. Send me an email to discuss.
    dave.lelonek@**********.com
    Thank you.
  8. ideloera
    Jun 2, 2015
    525
    Chicago
    Isi
    Johan, even if you buy new, it's only a matter of time before they get sticky again. Might as well have your old ones refurbished by Dave (sticky RX).
  9. docapl
    docapl Formula Junior
    Apr 26, 2002
    401
    SF Bay Area
    Anthony
    Would appreciate any advice for proper way to remove the trim piece after the radio is out. I assume referring to the large carbon fiber piece that surrounds the window switches and vents. Looks expensive and I don't want to damage it. Thanks! Image Unavailable, Please Login
  10. VAF84
    VAF84 Formula 3
    2,279
    Central Texas
    Just resurrecting to say thanks to those who posted on how to do this project. I successfully changed mine out. I was worried the directions would be too vague since I thought there would be more to it. However, it turned out to be one of the easiest DIY projects I've done on the car. I purchased my window switches from Eurospares.
    One note; it's probably worthwhile to disconnect the radio and put aside. I caused some light scratching to the a/c vents from trying to do this while keeping the radio connected. If you don't disconnect, watch out for the vents, or maybe cover them. Aside from that, it's seriously easy.
    Second note: I initially thought I could pull up once removing the four small screws around the "F430" plate, but you need to remove it and there are two more underneath. So don't get ahead of yourself and start "yanking" on the trim after removing those four screws.
    Qavion likes this.
