F430 PPI Compression Results | FerrariChat
Discussion in '360/430' started by Smaug, May 17, 2011.
  1. Smaug
    Smaug Karting
    May 9, 2011
    106
    NoVA
    Jeff
    Hi All,
    Just had a PPI done on an F430 and got some low numbers on the compression test (inspector did not have time for leak down test at this time). Not much variance between them (good) but a lot lower than the 11.9:1 spec on an F430 (bad). Any thoughts? Thanks!
    1 - 155
    2 - 155
    3 - 150
    4 - 152
    5 - 155
    6 - 155
    7 - 155
    8 - 155
  2. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Im not expert but my car had an average of 182 psi.
    I have 360
  3. mr_bock
    mr_bock Formula 3
    Oct 27, 2006
    1,373
    FL full time
    My M5 were around 190 psi... How many miles are on the car? If not broken in right, could have glazed bores? Still not broken in? Not sure what the psi 'should' be, but someone should chime in on that.
    Good Luck!!!
  4. Smaug
    Smaug Karting
    May 9, 2011
    106
    NoVA
    Jeff
    The car has 10k miles.
  5. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Im not sure but I think Brian mentioned that the 360 should have 200 psi but also varies with the technician who makes the test.
  6. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
  7. mr_bock
    mr_bock Formula 3
    Oct 27, 2006
    1,373
    FL full time
    #7 mr_bock, May 17, 2011
    +1, I am sure there is a procedure involved to get proper results. There was a good write up for the M5 that I followed exactly and repeated to make sure results were consistant.
    10K miles should put it right in being broken in...
  8. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    The results are nice and tightly grouped which, as you say, is good but they do appear low.
    What did the PPI chap have to say about it or did he simply give you the numbers without comment? Depending on his method of work I would have thought that he'd be able to say that those numbers were consistent with other 430s he's tested or (perhaps) significantly lower.
    Generally speaking one wants to have the throttle in wide open position when pressure testing. On a mechanically operated throttle that's easily done (but probably still makes it a two-man job) but with electronically controlled throttle bodies (and electronics and injection disabled for the test) it's not as simple. Your tester may have tested with throttle bodies in place and closed. If this is the case the results might actually reflect perfectly well on the engine.
  9. Smaug
    Smaug Karting
    May 9, 2011
    106
    NoVA
    Jeff
    I received his report by email. He did not note that the numbers were cause for concern. I will call him in the morning.
