F430 Problems - F1 Pump / Actuator / Solenoid Valve | FerrariChat
Discussion in '360/430' started by cmnho, Mar 2, 2010.
  1. cmnho
    cmnho Karting
    Jan 4, 2006
    166
    Singapore
    CM
    Dear All
    Recently, and just before the expiry of the 3 year warranty, I experienced increasingly frequent problems with the "SLOW DOWN" warning coming on and the gear being cut to neutral automatically. This usually happens when I am slowing down quickly from fairly high speeds. At times, right after the engine is started, and the car is put into gear (whether 1st or reverse), the car will barely move. The accelerator may be depressed and you can hear the engine come to life but there is little or no torque. Or it could be that the torque is just not transmitted to the wheels.
    When I first noticed the "SLOW DOWN" issues a few weeks before the warranty expired, I sent the car in for checking. However, I was told that the diagnostics computer did not find anything wrong with the car. However, when the problems not only re-occurred but became more frequent, I sent the car in again. I told the agent that they have to fix the problem and I will consider it a warranty claim since I notified them in time.
    After using the computer to diagnose the problem again, this time they found something at fault with the car. And this is currently the source of my frustrations. I am based in Singapore. The way that the car is being diagnosed and rectified is as follows. The local mechanics will plug in the computer and obtain the necessary readings. These readings will then be transmitted to the factory in Italy. The factory will then transmit instructions to the local mechanics to attempt the repair by replacing particular items/equipment, etc. Readings from the computer will then be taken and transmitted back to Italy. This process will be repeated until the problem is resolved. This has been going on for more than one week and till now they still do not know what the problem is with the car. They have taken out and replaced, amongst other things, the F1 pump, the actuator, the solenoid valve, etc but nothing appears to work.
    And they can't tell me when they will be able to resolve the problem. From other threads, I gather that the entire F1 kit may have to be replaced but since this is very expensive, I assume that the factory will try to avoid doing this until there is no alternative. To replace the F1 kit, they will have to send the kit all the way from Italy and that is another frustrating wait!!
    I'm just posting this to vent my frustrations and also at the same time ask if anyone has faced similar problems with their F430s and share how these problems were finally resolved.
    CM
  2. Hawkeye
    Hawkeye F1 Veteran
    8,177
    2007 F430?
    Coupe or Spider?
  3. cmnho
    cmnho Karting
    Jan 4, 2006
    166
    Singapore
    CM
    Feb 2007 Coupe
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    This may sound dumb but could it be your clutch is worn out ?
  5. cmnho
    cmnho Karting
    Jan 4, 2006
    166
    Singapore
    CM
    I don't think so. But just as I finished venting my frustations online, I received a call from the local agent. The factory has authorised the replacement of the entire F1 kit! The only issue now is how long it will take to arrive from Italy ...
  6. jomana
    jomana Formula Junior
    Aug 6, 2004
    367
    I had the same problem with my 360. First they told me it was the clutch. so i changed it but the problem didn't go away.
  7. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    Yikes. More F1 problems. Good luck. Hopefully it will be resolved soon.
  8. cmnho
    cmnho Karting
    Jan 4, 2006
    166
    Singapore
    CM
    Finally! After 2 weeks, the F1 issue has been resolved. The factory authorised the replacement of the entire F1 kit (actuator, F1 pump, solenoid valve, etc) and it's finally arrived and fixed onto my car. Thank goodness i managed to make the claim in time. The whole kit would have cost tens of thousands of dollars. The local agent here was quite apologetic about the long delay in repairing the car and were quite nice about it. They kept me informed on a daily basis and even gave me a small hamper of goodies for keeping me waiting! Good on them!
    Anyway, the car feels good and the F1 gear change slightly more responsive (or is it psychological?). The only thing is - there is now a new and quite loud metallic scraping noise that comes from the direction of the new F1 kit that comes on intermittenly. I will monitor that and bring the car in again if the noise persists. The exhaust note also sounded a tad softer than before. Wonder why ...
  9. MamoVaka
    MamoVaka Formula 3
    Jul 31, 2006
    1,409
    Los Angeles, CA
    Pano S.
    #9 MamoVaka, Mar 10, 2010
    tens of thousands of dollars? is this US dollars?
    if it was out of warranty you probably wouldn't replace everything as they did here.. just the faulty unit.. I think the actuator is 10k or so..
  10. cmnho
    cmnho Karting
    Jan 4, 2006
    166
    Singapore
    CM
    Yes, that woudl be tens of thousands (both in US and Singapore dollars). The factory tried replacing each of the component of the F1 kit in turn but could not resolve the problem. That was why it then approved the replacement of the entire kit. The only question now is whether I take up the power warranty extension ...
  11. tazandjan
    39,163
    The entire F1 Assembly was upgraded at Assembly No. 69347, and there were four separate F1 ECUs, including one that was compatible with a noise kit. These changed at transmission numbers 3270 and 3781, and also at serial number 157671.
    You might ask your dealer about the noise kit and see if he has a sense of humor. The entire F1 assembly is ~$15K here in the US for parts alone, so you are lucky it was under warranty.
    Taz
    Terry Phillips
  12. cmnho
    cmnho Karting
    Jan 4, 2006
    166
    Singapore
    CM
    Hi Terry, what's a noise kit and what does it do?
  13. tazandjan
    39,163
    Beats me. Reduces noise somehow. Just saw it in the parts catalog for the f430 F1 ECU, and you said your system was making noise. Worth asking your dealer.
    Taz
    Terry Phillips
  14. fiky
    fiky Rookie
    Jul 27, 2008
    16
    Hi guys, I need some advice about my f430 spider. This morning when i tried switching on the engine i had problem changing the gear ( Mine is F1 transmission btw) I didnt get warning lights but i have trouble shifting the gear when i start the engine. I had to paddle many times before the gear shift to 1. But after it changed to 1 (AUTO MODE) then it works perfectly. But when i want to switch off the engine i had trouble shift back to N. Its lagging. I still can hear the air F1 pump when i opened the door. Any clues guys ?
  15. MamoVaka
    MamoVaka Formula 3
    Jul 31, 2006
    1,409
    Los Angeles, CA
    Pano S.
    most of the cost is the actuator.. for some reason they charge 10k for it? that is shocking to me..
    pump is like 2k-3k I think..
    I dunno but that actuator thing is a mess.. fortunately it seems its a rarity for it to go bad.. but man that is not a cheap fix.
  16. jinferno
    jinferno Rookie
    Apr 5, 2009
    32
    OMG!!!
    I had the exact same problem recently (2007 F430 feb. build as well) and had to have the entire F1 kit replacement parts and I also had it done JUST BEFORE my warranty expired!!! I wonder if there needs to be a factory campaign for this. This is a very expensive fix indeed (please see my post). My local dealer went back and forth with FNA trying to diagnose the problem and finally just replaced everything ( my car couldn't get in gear). Somehow I just do think that are two problems are a coincidence.
    J
  17. Exact10
    Exact10 Karting
    67
    Pleasanton, CA
    Annie's Daddy
    My car, an F430 Coupe had problems when I bought it in 08, on the way home it simply wouldn't go into gear when I attempted to move off. I thought that it was something I was doing wrong as it was the first time I'd driven the system.
    It seemed to go away after that but came back intermitantly, it all came to a head when I'd try to reverse onto my drive, my approach is on a hill so the cars nose would be high.
    Soon as I tried reverse I would hear the system cycle and then it would just drop into neutral.
    I took it to Ferrari of San Francico three return times, each time they couldn't get the car to repeat the problem. In the end they just fitted the whole F1 system.
  18. Robin360
    Robin360 Formula 3
    Dec 2, 2007
    2,094
    Europe
    Robin
    Expensive stuff.... and seems to be a problem on both 360 & 430.
    Last year I had my F1 pump & sensor replaced: 5K$
    This year the actuator: 7.5K$
    This is a 360, and out of warranty. The Power Warranty does not cover this.
    With the new actuator the gear shift is much more bumpy. Don't know if they need some running in perhaps?
  19. MamoVaka
    MamoVaka Formula 3
    Jul 31, 2006
    1,409
    Los Angeles, CA
    Pano S.
    I wonder how prevalent the actuator problem is.. f1 pump going once every 40k miles I can accept.. but the actuator? how often does this thing fail? 7.5k is a tough pill to swallow if it might happen every 20k miles (on top of everything else)
    one more reason a manual is a good idea
  20. cmnho
    cmnho Karting
    Jan 4, 2006
    166
    Singapore
    CM
    Seems like quite a common problem. I have read about this problem in other threads as well. Which was why I was able to discuss the problem with the local agent here. I have another 3 days to decide whether to renew the power warranty! I know there's another thread on this somewhere but would people advise that I buy this warranty seeing as how the F1 kit was just replaced? With the F1 kit replaced, there's a major problem out of the way right? Any other major issues I may expect over the next year or two?
  21. Z33
    Z33 Rookie
    Apr 16, 2007
    13
    Hi CMHO,
    How much does the extended warranty cost?
    Cheers,
    Z
  22. cmnho
    cmnho Karting
    Jan 4, 2006
    166
    Singapore
    CM
    In US dollars, it is about 4k, 5k and 7.5k, depending on the coverage required.
  23. jinferno
    jinferno Rookie
    Apr 5, 2009
    32
    I was in the same boat about whether to get the extended warranty. I opted out and will keep my fingers crossed.
    J
  24. Z33
    Z33 Rookie
    Apr 16, 2007
    13
    Thanks CMHNO.
    Presumbaly those packages are based on another year of coverage/miles?
    Even at USD7.5k, it is not too bad given that a replacement F1 unit is 2-2.5x that?
    Cheers,
    Z
  25. cmnho
    cmnho Karting
    Jan 4, 2006
    166
    Singapore
    CM
    Yes, Z. That's for an additional year of coverage. I've decided to take a chance and not buy a power warranty. Fingers crossed that the next major repair (fair wear and tear items excepted) over the next 12 months will not exceed USD4K
